- Thank you received: 11
do I need to rejet with just an exhaust?
- tachrev
- Rubber Side Goes Down
if your airbox is still intact - ive got a like new K/N drop in filter.. p.m. me and ill give/ send it to ya, only if you live in usa..i dont want to eat too much postage... know what? i got a small baggie with a bunch of jets you can have also, but they are for the VM series, not BS...will they work??
Man, that's cool. Isn't this place awesome. :woohoo:
Build Thread
- 9am53
- homebrew, and some bbq
- Thank you received: 3
Tell me about it...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If the bike pulls a little harder at wot, then at 1/2 throttle, then when pulling away from a light/stop, you're fine!
If you get a bit of popping on decel, its still ok if its not too loud or annoying. You can clean that up with a pilot screw adjustment.
If the pilot screw is closer to the intake side of the carb, its an air screw. Turn it in 1/4 to remove some air from the pilot mixture.
If the screw is on the engine side, its a mixture screw. Turn it out 1/4 to add pilot mixture.
Gooooood Luck!
Cheers!
PS. The VM series jets don't work for BS series carbs.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
'84 GPz900r
'71 CB350
