transmission undercutting
- cruspeed
16 Sep 2009 18:10 #322066
by cruspeed
78 KZ1000 project X 2
transmission undercutting was created by cruspeed
anyone know how many degrees past 90 they put on the gears to consider them "undercut"? Have a mill and was considering doing it myself, couldn't be that hard.
- timebomb33
- Thank you received: 10
16 Sep 2009 18:23 #322069
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic transmission undercutting
some outfit's use 7 degrees and some go ten if it's a street motor or road racer then it's a good idea to do both sides if drag racing then just the main thrust faces
- Thank you received: 797
17 Sep 2009 08:34 #322176
by 531blackbanshee
Replied by 531blackbanshee on topic transmission undercutting
cruspeed,keep us posted on this.i have a mill and rotary table as well and have been very curious about the angles and if you have to have a dovetail end mill to be able to get the angle cut without getting into anything but the nubs.
leon holmes
leon holmes
- MDawnz1
- Thank you received: 27
17 Sep 2009 19:52 #322291
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic transmission undercutting
uh,,,,
You do know that the gears are ONLY surface hardened ?
And will need to be rehardened when you are done ?
1974 Z1a, still 903
- racer54
- Thank you received: 114
17 Sep 2009 23:19 #322322
by racer54
Replied by racer54 on topic transmission undercutting
Are you sure about the rehardening after cutting the gears? A guy around here that does it just cuts them and goes. He's one of the best racers in the country...bar none. Actually the 2008 NHRA motorcycle world champion! R&D actually softens up the gears after cutting them so they aren't as hard and brittle as stock gears. You may be right though. It is something to think about...makes sense too, but not sure if everyone actually rehardens the gears after cutting them.
- timebomb33
18 Sep 2009 06:55 #322359
by timebomb33
i've never got mine redone after i've done them or gotten a trans from some other source but i have often thought about doing it but none of my trannies have failed to shift properly i broken gears but never hurt shift dogs so i havent got them hardened oh i by the way i thought i was one of the best racers in the country? i'm hurt. :blush: :woohoo: :side:
- PLUMMEN
- Thank you received: 104
18 Sep 2009 10:09 #322381
by PLUMMEN
Replied by PLUMMEN on topic transmission undercutting
if its just a hot streetbike i wouldnt waste the money myself,im about as abusive as anybody i know on stock transmisions and have never seen the need on the average streetbike with skinny back tire that goes up in smoke really easy
