kZ 1000 sprocket cover mod
- gearhead119
22 Sep 2009 19:33 #323383
by gearhead119
2000 Zrx1100 Turbo-220bhp/145lbs torque
1978 KZ 1000 project-in progress
Replied by gearhead119 on topic kZ 1000 sprocket cover mod
Thanks you guys... I got it polished up and it looks pretty kool. I'll have to take my camera to work tomorrow and snap some new pics. As far as time... just the cutting and shaping... probably an hour or so... polishing.. .. .. uhh... 4 hours or so.. After sandblasting it take about 6 times over it to sand down to a polishable surface. Starting with 220 grit, then 400, then 600, then 800, then 1500, then 2000, .. a little steel wool and then polishing goes pretty quick...
polishing (like painting) is all in the prep work. The straighter and more perfect you can get it from the start the better the finished product will be. What stinks is now I have to match the quality with all the other covers!!:S Might do something a little different with a couple other covers.. not quite sure yet...
- Old Man Rock
- Thank you received: 225
22 Sep 2009 19:50 #323387
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic kZ 1000 sprocket cover mod
gearhead119 is now known as Buffhead119.... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gearhead119
23 Sep 2009 06:35 #323461
by gearhead119
I've been called worse!:laugh: :laugh: :laugh:
