- Thank you received: 1
Starter Clutch: '81 KZ 750 LTD (4 cyl)
- davehayward1
15 Sep 2009 17:48 #321857
by davehayward1
Starter Clutch: '81 KZ 750 LTD (4 cyl) was created by davehayward1
I'm trying to remove the starter clutch from the crankcase
How do I disengage it so I can slip it off the secondary shaft?
- Arnold
- Thank you received: 14
19 Sep 2009 10:29 #322510
by Arnold
Check out my project at:
kzrider.com/forum/11-projects/550823-ret...100-82-goes-z1-clone
Replied by Arnold on topic Starter Clutch: '81 KZ 750 LTD (4 cyl)
Hi Dave,
I fixed my starter clutch a while ago.
U can do it with the engine still in the frame. You just tap the crankcase out carefully form the right to the left and the starter clutch and chain will be so loose so you can take it off the sprocket on the secondary shaft.
It´s not that hard...you´ll work it out fine.
See the thread below for some more info.
/Arnold
kzrider.com/index.php?option=com_kunena&...d=2&id=182273#185849
/Arnold
- Arnold
19 Sep 2009 10:57 #322514
by Arnold
Correction !! The shaft comes out from left to right.
- davehayward1
19 Sep 2009 13:28 #322519
by davehayward1
Replied by davehayward1 on topic Starter Clutch: '81 KZ 750 LTD (4 cyl)
It worked!
I had some difficulty gatting the secondary shaft out
The Clymer Manual says to give it a few taps and pull it out.
In reality you need something long with a blunt end and have to do alot of tapping on the left end before it comes out the right side
The starter clutch slips right off of the chain and comes out in one piece.
Hint: there is no need to take off any circlips.
Here are some pix
picasaweb.google.com/davehayward1/Starte...uDoejfWg&feat=email#
Thank you!!
Here are some pix
Thank you!!
- davehayward1
20 Sep 2009 04:04 #322620
by davehayward1
Here are some pix of the starter clutch
One of the springs was broken
Amazing a little thing like this could wreak so much havoc!
Now - to put it all back together and see if it works!
picasaweb.google.com/davehayward1/Cluch?...v1sRgCPKirYjtkcyfWA#
- Arnold
17 Oct 2009 09:28 #328020
by Arnold
Good to hear that you got it working again !
I agree, a small broken spring and the bike is almost useless.
- davehayward1
17 Oct 2009 10:08 #328024
by davehayward1
Well - - it's almost fixed
Before I repaired the starter clutch it would not start at all - just the "rattling" noise when I pushed the start button
I still get the rattle but infrequently
My guess is - it'll get worse if I don't do something about it
Sounds like I'm shaking gravel in a coffee can
Something else is going on and I haven't got a clue - - -
- MFolks
- Thank you received: 540
17 Oct 2009 10:23 #328027
by MFolks
Replied by MFolks on topic Starter Clutch: '81 KZ 750 LTD (4 cyl)
Try this check list for possible solenoid problems:
Starter Solenoid Checkout
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery, and then use a floating ball hydrometer to check specific gravity in the charged cells).
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. Some websites for starter motor rebuild kits are:
A. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
B. www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot ,so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
- davehayward1
17 Oct 2009 10:28 #328028
by davehayward1
Thanks!!
