low power
07 Sep 2009 19:41 #319783 by Eddie68
low power was created by Eddie68
I have a 1980 z650. The engine sounds great and goes great up to 7000 revs in 5th gear, but thats it. I only get 150kmph out of it. I have the timing spot on, I have also changed my petcock and main jets to 105s but nothing makes any difference. What else should I check? cheers in advance!
ed
07 Sep 2009 20:11 #319787 by MFolks
Replied by MFolks on topic low power
Checked the compression? Adjusted/checked the valve clearances? Running correct sparkplug gap and heat range? Replaced sparkplug high tension leads and sparkplug caps?
Adjusted cam chain tension? If not electronic ignition, replaced the points and condensers?
Checked primary(small wires)side of the ignition coils for battery voltage? If down around 8-10 volts your bike is suffering from low spark energy.
07 Sep 2009 20:14 #319790 by PLUMMEN
Replied by PLUMMEN on topic low power
how fast is 150kph? B) its only a 650! :laugh:
07 Sep 2009 20:53 #319798 by Bluemeanie
Replied by Bluemeanie on topic low power
About 93 mph. (120 mph, give or take is feasible for these bikes)
Ed, do you max out at 7000rpm in the first 4 gears also?
08 Sep 2009 00:39 #319818 by Eddie68
Replied by Eddie68 on topic low power
I max at about 7500 in fourth!
08 Sep 2009 00:48 #319819 by Eddie68
Cam chain is good! have not checked volts at coils, will do. dinna electronic ignition fitted, so no points. BP7es plugs, valve clearance good. I have pods and 4 into 1 pipes, just fitted. Could the pods be the problem do you think? plugs tanned brown, so mix looks good.
08 Sep 2009 00:50 #319820 by Eddie68
not fast enough!
08 Sep 2009 00:53 #319821 by Patton
Replied by Patton on topic low power
:unsure: When the throttle grip is being held wide open, are all the carb throttle slides going into their highest position?
Good Luck! :)
08 Sep 2009 04:22 #319825 by lapeerray
Replied by lapeerray on topic low power
Is it wheely poppin scary fast up to 7000 rs? Maybe you need to change your spockets?
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
08 Sep 2009 05:11 #319831 by chance
Replied by chance on topic low power
Thats about top speed unless you do some sprocket changing....
08 Sep 2009 08:37 #319862 by pitblue/kz
Replied by pitblue/kz on topic low power
if that doesn't work then get a bigger bike
  • KOOL RYDER
  • KZ 650B2 / KZ 1000E
08 Sep 2009 09:07 #319867 by KOOL RYDER
Replied by KOOL RYDER on topic low power
I can chime in here. My bike, KZ650B, was topping out at 160kmph and it would stop gaining any more speed.
It had the airbox, points, stock gearing, basically a stock bike aside from a K&N filter.
After checking the plugs (B7ES) noticed they were fouled and black, I had the points adjusted and cleaned, the timing adjusted, adjusted the pilot screws, had the carbs synced, and completed the WG coil mod.
Now my bike can pull well past 160kmph. I have yet to find the the new top speed on my newly tuned machine.
The most noticable difference came from the power mod and timing adjustment.
If you already have 12 v at the coils then the power mod will not help.
Make a check list and go through the necessary steps and your bike will definately acquire a new top speed.
KR B)
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
