low power
- Eddie68
ed
- MFolks
- Thank you received: 540
Adjusted cam chain tension? If not electronic ignition, replaced the points and condensers?
Checked primary(small wires)side of the ignition coils for battery voltage? If down around 8-10 volts your bike is suffering from low spark energy.
- PLUMMEN
- Thank you received: 104
- Bluemeanie
- Thank you received: 14
how fast is 150kph? its only a 650! :laugh:
About 93 mph. (120 mph, give or take is feasible for these bikes)
Ed, do you max out at 7000rpm in the first 4 gears also?
- Eddie68
- Eddie68
- Eddie68
- Thank you received: 2098
Good Luck!
- lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- chance
- Life long biker/
- pitblue/kz
- KOOL RYDER
- KZ 650B2 / KZ 1000E
It had the airbox, points, stock gearing, basically a stock bike aside from a K&N filter.
After checking the plugs (B7ES) noticed they were fouled and black, I had the points adjusted and cleaned, the timing adjusted, adjusted the pilot screws, had the carbs synced, and completed the WG coil mod.
Now my bike can pull well past 160kmph. I have yet to find the the new top speed on my newly tuned machine.
The most noticable difference came from the power mod and timing adjustment.
If you already have 12 v at the coils then the power mod will not help.
Make a check list and go through the necessary steps and your bike will definately acquire a new top speed.
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
