Snapped a Bolt
- davehayward1
Snapped a Bolt
04 Sep 2009 15:18
Removing the exhaust from my '81 KZ 750 LTD (H$) I snapped the thread off the bolt that secures the exhaust pipe collar to the block
Can't tell if it is screwed into the block or molded
If it's screwed in, I'm thinking I can unscrew it with vice grips.
Might have to tap it with a hammer as I'm exerting counterclockwise pressure
Has anyone ever seen this done?
- muddy1
- 1980 Kz1000 LTD B4
Re: Snapped a Bolt
04 Sep 2009 15:23
the stud is screwed in. Visegrips should work
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Re: Snapped a Bolt
04 Sep 2009 15:38
Before you take a chance on snapping it off even shorter, soak it for a day or two with Kroil. Ed
- davehayward1
- trianglelaguna
Re: Snapped a Bolt
04 Sep 2009 17:42
do not wear it down flush...get a good bite on it,,,if it becomes flush..it can start a downhill experience...i have vice gripped em off ..it works.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- gane
Re: Snapped a Bolt
04 Sep 2009 18:08
Dave, Do EVERYTHING you can to ease removal while you still have a stub to work with, IE; multiple applications of penetrating oil, sharp raps w/hammer, and as crappy as it makes the job, bring eng. to temp. by running. It may be overkill, but, once stud is broken flush at head. things get ugly. Luck g
[img][/img] 1977 KZ1000A1
- davehayward1
Re: Snapped a Bolt
05 Sep 2009 07:46
Thanks to you both. There's plenty of stud to work with so hopefully it'll come out. I'll take it easy. Thanks for the words of warning
I checked the Z1 site and I'll be damned if they don't have it!
Sometimes you just have to sit back and wonder - what did we do before the internet came along?
Maybe you can help with my current issue
I'm trying to get the "clutch basket" off, which is secured with a 30mm locknut.
I'm using a "clutch holding tool", 30mm deep socket, and 15" breaker bar.
Should turn clockwise to loosen - - no?
Not making any headway (in either direction)
Suggestions?
Thanks again
Suggestions?
Thanks again
- davehayward1
Re: Snapped a Bolt
05 Sep 2009 07:50
Oops! The "Z1" reference was intended for someone else who referred me to
www.z1enterprises.com/
These guys stock the replacement exhaust port stud
Looks like a pretty good spot for parts. You might want to save it
- anarki650
Re: Snapped a Bolt
05 Sep 2009 07:52
Nothing beats air impacts for getting those clutch nuts off (also the countershaft nut that holds the front sprocket on). Oh, the thread on that nut is standard thread, lefty loosey, so turn counter clockwise to remove.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- timebomb33
Re: Snapped a Bolt
05 Sep 2009 08:59
if you don't have a air impact gun then go to harbour freight or tractor supply and pickup a 1/2" electric impact it will peel that nut and anyother nut right off. turn counterclockwise it has right hand thread if your use hand tools on things like that for removal your trying to too many things at once and wrenches will slip people can get hurt and many expensive parts can break or get damaged. try to use the proper tool for the job that is why us pro's have so much money invested in tool's. if your in canada the go to canadian tire this weekend they are having a sale on electric impacts with a full three year warrenty do you self a favor all off you should buy one and you wont have problems in the future removing nuts or bolt air is great but not every body has a compressor but everybody has 110 household current you will be impressed with the power. i used one for 8 winters working in oil patch up here when it was sometimes 40 below zero and it never failed me.
I THINK MY POWERBAND BROKE
- davehayward1
Re: Snapped a Bolt
05 Sep 2009 10:43
Thanks!
My neighbor loaned me his electric impact wrench
Nut's off
I'm back in business
Time spent?
5 seconds
Harbor Freight has these amazing tools for as little as $30
Thanks again
Nut's off
Time spent?
5 seconds
Thanks again
- gane
Re: Snapped a Bolt
05 Sep 2009 16:45
Dave, Perhaps I'm missing the big picture...But on my '77 1000 cl basket removal means splitting cases. else I would have had a billet basket months ago. curious g
