- Thank you received: 5
'81 KZ650 timing/starting trouble
- fixer5000
06 Sep 2009 15:24 #319556
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic '81 KZ650 timing/starting trouble
massachusetts
- TriniTT
06 Sep 2009 18:37 #319607
by TriniTT
Replied by TriniTT on topic '81 KZ650 timing/starting trouble
Thanks for the response. I finally came across a manual fpdf file or my specific engine/year, and the number is claimed to be b/t 45/46. With the Z6EX mark parallel to the front of the head on the exhaust cam, and the IN line on the intake cam parallel to the rear of the head, count 45 teeth from the exhaust cam and the IN line should be directly after the 45th pin.
Is there anywhere I can submit the manual pdf on this site? I tried finding it in the filebase here and it's not there.
