- Thank you received: 225
I can't find my kz book. Need head torque specs
- Old Man Rock
29 Aug 2009 17:52 #317433
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic I can't find my kz book. Need head torque specs
Pretty much identical for the Z1, KZ900, 1000 & 1100 series.... In my manuals anyways...
As mentioned, sequence is extremely important...
Following the sequence, snug fit through the sequence then go back through the sequence for torque values...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Nephlyte
- To do what is right is to know what you want.
30 Aug 2009 09:15 #317559
by Nephlyte
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
Replied by Nephlyte on topic I can't find my kz book. Need head torque specs
Ya, we'll see. But i just took it for a 100 mile spin yesterday after i fixed that noise and still no problem.
I'm gonna take it out for another 50-100 mile journey today. I should probably clean it up a bit too.
- Thank you received: 2098
30 Aug 2009 09:40 #317565
by Patton
Replied by Patton on topic I can't find my kz book. Need head torque specs
Be sure engine is completely cold when re-torquing.
Likely good to re-torque more than once. (After another heat>cold cycle, of course).
Good Luck!
Good Luck!
