Trouble starting my new (to me) '77 KZ650
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Here is what I did, and it did not cost a ton of money....
1) NGK B7ES Spark Plugs - a new set will make you a happy camper. The bike will be much easier to start.
2) New Battery - if the battery is not new then splash out 50 bucks and get a new one. Do not forget to bring the old one in to get the environmental levy refund.
3) After the new battery has been installed check the voltage at the coils to ensure 12 V. If not getting 12 V with the new battery at the coils, then do the WG coil mod, again not expensive and there is a lot of material on this site to help you get it completed.
4) Check the fuses to make sure they are not corroded, a new set of fuses would not hurt either and is a cheap way to buy peace of mind. A lot of fuse boxes get pretty ugly over 30 years and a new fuse box will run you $20.00 (Try Z1)
5) Buy a battery tender or trickle charger (again $20) to keep your battery charged in between rides to prevent having to jump the battery, which is not really the best idea to get it stated. Some come with a boost option built into them.
6) As mentioned above - check and service points and timining and look into getting the carbs synced.
Over time if you desire, you can tweak and tune the carbs and repace the airfilters.
I always have an extra set of plugs under my seat in the tool tray with a spark plug wrench just in case you are left stranded someplace.
Last but not least, make sure there is enough gas in the gas tank, do not ask how I know that...lets just say that I was a newbie with these bikes once.
You will have a reliable ride, it will just take a little work, a few knuckle scrapes, and a few extra bucks to get it to become a reliable ride.
I like the colour of your bike, just like mine.
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Bluemeanie
- Thank you received: 14
fixer5000 wrote:
on my 78 i put the choke on full. usualy it starts right up and rpms rocket up so then i put choke to about halfway. i think you need to check the voltage at your coils with the key on. sounds like a coil mod candidate
I tried searched for "coil mod" but can't seem to find anything. Do you have a link so I can read up on it?
Here is the link to the coil mod. Works wonders and cost less than $20!!
- ckotul
1977 KZ650C1
- Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- ckotul
Could you give a little history on this fine machine. Was it sitting for a longtime? Is the gas new? What is the longest you have had it running? Have you ridden it for any distance? When it is running how does it run?...Russ
Was sitting for less than a week when I bought it. Guy fired it up after a little tweaking of choke and all was good. Gas is new. I've run it for about 30 minutes since I bought it on Monday, and everything seems fine when it's on the road. The only problem I'm having is when the bike cools down it's a pain in the @$$ to start again.
1977 KZ650C1
- Forrest
- The Mad Duck
- Thank you received: 180
Anyway, you probably can tell from all the postings and my lengthy reply that there are several things that need adjusting/maintaining on old bike like these. I would either spend the money or have a knowledgeable friend help with your engine/carb tweaking. My bike is now running like a champ and yours likely can too.
- ckotul
I can't get this bike started for the life of me. I'm wondering if I'm doing something wrong with the choke?? Here's the order I'm doing things:
1) turn the fuel on
2) put the choke in the "ON" position (all the way up)
3) turn the ignition on
4) turn the kill switch to RUN
5) engage the clutch
6) press the start button
The bike will turn over, but after a few tries it stops sounding like it's actually turning over and starts to emit more of a clanging noise. Am I flooding it? If I am flooding it, how long do I wait until trying it all again?
1977 KZ650C1
- tinlizzie37
Bob KZ 650 E1, En 450
- Thank you received: 2829
- lrburke
- ckotul
What plugs are in it?
Champion RN4C
According to Champions website, these are the correct plugs, so I think I'm good.
1977 KZ650C1
- ckotul
I noticed on your profile that you live in Ohio! How far are you from Cincinnati where I live? I guarantee that every person that has responded to your post wishes they could be there helping you but we don't always live close enough to do that. When I saw you lived in Ohio I figured if we live close enough I would be glad to help you any way I can. I am an actual bike mechanic and have dealt with a lot of these vintage bikes! It's kind of overwhelming when you have several people giving you advice (all good) but your really not familiar with much they are saying. You need to be taken step by step through the troubleshooting procedure so you can systematically come to the problem. I hope the other guys on here don't get offended by this message! I am only trying to help! My e-mail is burkes3gz@zoomtown.com if you are interested. Thanks
Believe me, I'd be interested... if only I lived in OH. I think that having someone who is familiar with KZ's walking me through step by step is EXACTLY what I need. I'm actually in Northwest Indiana about 30 minutes outside of downtown Chicago, so if anyone around me is willing, please please please let me know! Thanks for the offer though!
1977 KZ650C1
