Trouble starting my new (to me) '77 KZ650
- ckotul
I put the choke all the way ON (up position), make sure the fuel is on, hold the clutch, push the button. It turns over, but doesn't start. Wait a few seconds, try again with the choke in the same position (all the way up). Same thing, except this time I hear the engine trying to start, but still won't fire up. Wait a few seconds, adjust put the choke in (down) a little, try again, same thing.
Am I doing something wrong here? This is my first bike, so forgive me if I'm making a newbie mistake.
Here she is:
1977 KZ650C1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- ckotul
1977 KZ650C1
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2829
Petcock on
Choke up
do NOT touch throttle
Ignition on
A couple swift kicks on the kickstarted and it fires right up
OR instead of kicking, pull in clutch and hit starter button.
You may want to contact the previous owner and ask if he had some secret formula for starting the bike.
- ckotul
1977 KZ650C1
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- ckotul
Have you tried starting it with the headlight in the off position?
Not yet, I'll have to try that when I get home.
1977 KZ650C1
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
- ckotul
on my 78 i put the choke on full. usualy it starts right up and rpms rocket up so then i put choke to about halfway. i think you need to check the voltage at your coils with the key on. sounds like a coil mod candidate
I had the bike running last night (after I jump started it) and it revved up to 5k rpm. That's the only time it's done that since I owned it, which is 3 days.
I tried searched for "coil mod" but can't seem to find anything. Do you have a link so I can read up on it?
1977 KZ650C1
- ckotul
Have you tried starting it with the headlight in the off position? Let me guess when warm it starts right up. I would also use starting fluid on cold starts but that might not be best for your motor.
Stupid question... but I'm going to ask it anyways because I don't know. Where would I spray the starting fluid when using it to start the bike? Directly on the air filter pods?
1977 KZ650C1
- lrburke
