clicking??
- Bicycle Lee
HOLY SH*T!
And yeah, I used engine assembly lube in cam bearing races, valve shims, etc...
No more smoke from exhaust after about two miles of riding...still some from the crankcase breather, but I'll keep letting it work itself out hopefully. I still have some hesitation in low rpm's but I think that's a pilot jet issue?? I'll post in the carb section and see what people say....
After I give it a few more miles I'm gonna re-torque everything in the head: cam chain guide assembly, valve cover, etc...
Thanks to everyone who has helped me along the way. I'll post some pics soon...
oh and PS: cranked the exhaust nuts down and the clicking got better... not quite gone, but way better...
1978 KZ1000 police
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Bicycle Lee
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Bicycle Lee
1978 KZ1000 police
- kano
- Not Another Bloody Limey!
you want a good seal if not later down the road you could chip a valve like i did and ended up replacing a sleeve piston and valve just because a bad exhaust stud.
- Bicycle Lee
1978 KZ1000 police
- kano
- Thank you received: 2829
Kano
- edspring1
- Thank you received: 3
so BEWARE !!! Oveahead valve engines utilizing adjustment shims are no different.
- bountyhunter
- Thank you received: 337
You can by the zinc-phosphorous additives now from ZDDPlus which will restore motor oil protection to previous levels.i surely don't know it all but i would like to add this much. assembly lube or not USE OIL THAT HAS 'ASH' IN IT or a additive specifically designed for rebuilt engines. the govnt. made the oil mfgrs. remove the ash a few years ago and we are now seeing the results. i was at my builders this past saturday and he showed me a follower/lifter that had just 20 miles on it. the cam side of it was worn OFF atleast 3/8". the mating cam lobe was about completely gone. the customer used assembly lube only. [new cam & followers] this lack of ASH in oils is causeing problems like this all over. in the automotive as well as M/C. anything that has NON roller type lifters. the builder says he is starting to see this sort of thing on a weekly basis.
so BEWARE !!!
- Bicycle Lee
1978 KZ1000 police
