clicking??
- Bicycle Lee
clicking??
22 Aug 2009 09:27
So we fired the motor for the first time since we took it off the engine stand and put it in the frame. fired up easily enough, but I noticed a "clicking" noise coming from the 1&2 side of the motor...
it didn't have it when it was on the stand... could manhandling the thing to get it in the frame cause anything to jar loose?
Anyone have any ideas of what it could be?
1978 KZ1000 police
- flht1997
Re: clicking??
22 Aug 2009 10:11
perhaps an exhaust leak at the head? can often sound like a click
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Bicycle Lee
Re: clicking??
22 Aug 2009 14:11 - 22 Aug 2009 14:12
hmmmm... I don't know if it is that... I'll tighten the nuts and see if it gets better...
tomorrow, I ride!
I also have some smoke? coming out of my crankcase breather? Is that normal? If not, what could cause that?
tomorrow, I ride!
1978 KZ1000 police
Last edit: 22 Aug 2009 14:12 by Bicycle Lee.
- bountyhunter
Re: clicking??
22 Aug 2009 14:49
Did you install new donut seals on the exhaust pipes?
- Bicycle Lee
Re: clicking??
22 Aug 2009 15:43
you mean the little fiberglass exhaust gaskets? Yeah, I put a new set on.
1978 KZ1000 police
Re: clicking??
22 Aug 2009 16:07
I think bountyhunter meant the copper gaskets that go between the pipe and the head.
- kano
- Not Another Bloody Limey!
Re: clicking??
22 Aug 2009 16:09 - 22 Aug 2009 16:10
normally exhaust leaks get described as a ticking,
i have had this before,
start up your old girl
and while its running pinch up exhaust studs till it go's away,
if it doesn't you may need to double up the copper rings.
Last edit: 22 Aug 2009 16:10 by kano.
- Bicycle Lee
Re: clicking??
22 Aug 2009 16:41
I'll give that a shot, Kano... thanks
I know I need a new set of exhaust lock nuts....
1978 KZ1000 police
- Bicycle Lee
Re: clicking??
22 Aug 2009 21:54
anybody have any ideas about the "smoke" coming from the crankcase breather tube?
1978 KZ1000 police
- timebomb33
Re: clicking??
22 Aug 2009 22:39
is this a fresh topend job and if so have you run it at all other than starting it sounds like it is due to the rings not fully seated. giveit some time and it should quit when the motor is broken . does the exhaust smoke as well.
I THINK MY POWERBAND BROKE
- Bicycle Lee
Re: clicking??
23 Aug 2009 09:48
yeah, new rings, new valves, port work...
I've run it a little bit on an engine stand, but maybe a total of twenty minutes.
the exhaust does smoke as well, but that probably has something to do with there being oil in the old headers too... I'll just give it some more breaking in and see if it quits...
1978 KZ1000 police
- Old Man Rock
Re: clicking??
23 Aug 2009 10:25
As I learned the hard way (Verbal Spanked by Plummen & Larry C :blush: ) did you use Engine Pre Lube up in the head?
Also, if my memory is correct, another member just went through something similar and it was the top idler assembly bolts where his problem, clicking on the valve cover...
As already mentioned, smoke is normal during break in periods...
Don't forget... 50 miles then change oil and filter...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
