help with compression 76 kz750b
- petunia76
- 81 KZ1000 76 KZ750 Twin..77 KZ650 4
19 Aug 2009 09:07
Hi,
I've looked everywhere here and cannot find anything about acceptable compression. When I first got my bike a couple weeks ago Ipulled the spark plugs & poured some marvel mystery oil down it just in case there were some sticky rings and etc.So I guess I just did a wet compression test. I should have done the dry 1st. Another contributing factor at least I think is if I dont apply all my weight and have good fast kick Im not getting all the stroke . Anyways when I did the check I got 45 psi on one cylinder and 85 psi on the other. I've yet to get her fired over and have no wiring so it has to be done by kick. SHould I get someone with a little more butt behind them to kick it? Im about 5'6" 130 Lbs.The bike has been sitting for I dont know how long but its not frozen up .
1976 KZ750B Twin, 1977 KZ650B,1981 KZ550
- bountyhunter
Re: help with compression 76 kz750b
19 Aug 2009 12:22 - 19 Aug 2009 12:23
petunia76 wrote:
Nominal compression is about 150 psi
Service limit: 115 psi with less than about 15psi from min to max.
These are HOT readings, no cold specs are given in the manual.
NOTE: the engine will not run with 45/85 compression.
On the 750 twins:Hi,
Last edit: 19 Aug 2009 12:23 by bountyhunter.
- timebomb33
19 Aug 2009 16:06 - 19 Aug 2009 16:08
how did you do the compression test did you hold the throttle wide open and kick it until the gauge quit climbing or as just once and take the reading. just trying to clear things up.also try taking both plugs out and then trying it it will make it easier to kick over it is a big twin after all.
I THINK MY POWERBAND BROKE
Last edit: 19 Aug 2009 16:08 by timebomb33.
- petunia76
20 Aug 2009 15:19
I just kicked once and took reading then switched gauge to cyl 2 and did the other side.
I don't even have a throttle yet.I want to make sure my motor is ok 1st .
- timebomb33
20 Aug 2009 15:29
you have to kick it until the gauge stop moving usally 5 or 6 good hard kicks
20 Aug 2009 16:17
petunia76 wrote:
Compression test requires plenty of air being sucked into the engine.
Usually accomplished by holding throttle twist grip in wide open position while cranking over the engine with electric starter or kick starter.
May also be accomplished with carbs removed from engine, with nothing such as rags stuffed inside or blocking the carb holders that would prevent plenty of air being sucked into the engine while cranking it over with the electric starter or kick starter.
Good Luck!
Good Luck!
20 Aug 2009 16:29
If the compression still reads too low after a properly performed compression test, the low compression may be resulting simply from too tight valve clearances.
So the valve clearances should be measured and assured to be within specs.
Even if valve clearances are within specs, one or more valves might be leaking instead of fully sealing when it's supposed to be closed in its seat. Such valve leakage will also cause loss of compression. But often it's only the clearance that needs adjusting.
A leak-down test helps determine exactly where any compression loss is going, whether past the pistons/rings, or through exactly which valve(s), or past a leaking head gasket.
Good Luck!
Good Luck!
