Rookie questions about my Kz900
- aforsythe
19 Aug 2009 05:22 #314992
by aforsythe
Adam Forsythe
76 KZ900
Rookie questions about my Kz900 was created by aforsythe
Hi, i'm new to the forum and recently bought a 76 KZ900 about 2 months ago and was wondering a few things about my bike;
about how often do the plugs need be changed? miles? inspect every oil change?
How tall is your 5th gear? Riding to work today i noticed 60mph = 4rpm, 70mph = 5rpm, 80 about 5.5ish.
Adam Forsythe
76 KZ900
- roy-b-boy-b
- Thank you received: 103
19 Aug 2009 05:27 - 19 Aug 2009 05:28 #314994
by roy-b-boy-b
Replied by roy-b-boy-b on topic Rookie questions about my Kz900
Welcome, Great looking bike. Gearing seems stock. I change my oil when it gets dirty no matter the mileage. It is also a good idea to change it before you store it. The plugs will just go and go. Check the gap every once in a while. Roy
Last edit: 19 Aug 2009 05:28 by roy-b-boy-b.
- Russ Jackson
19 Aug 2009 05:30 #314995
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Rookie questions about my Kz900
Very nice bike! Welcome to the forum. Your numbers seem to be correct. I change my oil at about 1800 miles and the filter every other oil change. I look at the plugs everytime I change the oil. Plugs will tell you when they need changing. Anytime the idle speed changes it is usually a plug issue. Got any more pictures?...Russ
- boots
19 Aug 2009 07:53 #315016
by boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
Replied by boots on topic Rookie questions about my Kz900
VERY VERY NICE!!!! That's one of the cleanest 76s I've seen yet!Good find!
Good Luck with her.
Later, Boots
Good Luck with her.
Later, Boots
81 cb650
- Thank you received: 2829
19 Aug 2009 08:11 #315020
by 650ed
Replied by 650ed on topic Rookie questions about my Kz900
Adam,
I have bad news for you. The museum called and wants their KZ900 back! That bike is beautiful!! A work of advice, if you don't already have one, buy a Kawasaki factory shop manual. Be sure to get one for your specific model/year; they're available on eBay. I can promise that you will not regret buying one! If the current plugs look a little tired I would change them now and check them every few thousand miles. Use a torque wrench when tightening, you don't want to damage that engine. Ed
- TerryK
- Thank you received: 3
19 Aug 2009 08:50 - 20 Aug 2009 13:52 #315029
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Rookie questions about my Kz900
Beautiful, clean 900. You don't see many like that any more.
I change my oil every 2500km (1550 miles). Hey, it's cheap insurance to keep the old girl happy. Plugs once a season, but you can go YEARS on the same plugs.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 20 Aug 2009 13:52 by TerryK.
- aforsythe
19 Aug 2009 09:23 #315039
by aforsythe
Adam Forsythe
76 KZ900
Replied by aforsythe on topic Rookie questions about my Kz900
Thanks! it's an awesome bike and i lucked out. Far as i know; the story goes that it only had 2 owners, sat in a basement for years and the guy i bought it from restored it fully - he put the vance & hines on it, picture doesn't show but it actually has crome valve covers, dyna ignition, and the handle bars are more like drag bikes - has 18000 miles. unreal.
I appreciate the feedback as i'm learning as i go with it.
-Adam
-Adam
Adam Forsythe
76 KZ900
- grumpy56
- Thank you received: 6
19 Aug 2009 12:40 #315085
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic Rookie questions about my Kz900
jealous..........
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Beatpoet
19 Aug 2009 14:56 #315102
by Beatpoet
Replied by Beatpoet on topic Rookie questions about my Kz900
All the info will be in the service manual.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
19 Aug 2009 15:35 #315112
by kzz1p
Replied by kzz1p on topic Rookie questions about my Kz900
Isn't there pictures of that bike on the net? I think so, very clean bike, take care of it.
- Oldwolf
20 Aug 2009 12:50 #315279
by Oldwolf
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
Replied by Oldwolf on topic Rookie questions about my Kz900
Beautiful!!
- larrycavan
- Visitor
20 Aug 2009 12:53 #315281
by larrycavan
Replied by larrycavan on topic Rookie questions about my Kz900
That's an exceptionally well cared for 76, 900!
