Slipping while in second gear
- timebomb33
Re: Slipping while in second gear
17 Aug 2009 07:48
do like patton say's and do a proper adjustment on the pushrod back your cable off both at the lever and also half way down the cable then remove the small cover in center of the sprocket cover undo the lock-nut then tturn the adjuster in a few turns clockwise then turn it back out counter clockwise until it gets some resistance then turn it clockwise a 1/4 of a turn and tighten the lock-nut then readjust your cable until you have about an 1/8" of slack at the lever try that before you go replacing anything in all my years of running these bikes i have never had to replace a complete clutch pack in fact all of my plates that i use in my drag bikes are used and very well seasoned 20'000 plus miles on every one and the only time i replace themis when i break fibers.
I THINK MY POWERBAND BROKE
- TerryK
17 Aug 2009 09:34
If it is jerky "in and out" like you describe then the trans is probably the culprit. If it's a smoother, revving up like you are slipping the clutch then look at the clutch adjustments and the plates themselves.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- saxjonz
- KawboyZ
17 Aug 2009 16:56
Now you never said you lived in Chicago my hometown... A bunch of us get together and ride all the time. It would be nice to have another kz rider in the group. I have a feeling your second gear is shot but I could tell for sure if we get together for a ride and end your wonder once and for all.
PM me if you want to get together and ride. I am free until next wednesday and then on weekends. saxjonz@hotmail.com is my email.
jbrewer73 wrote:
Im gonna wait til it gets a little colder here in Chicago to do this project. She has been riding pretty good lately. Trying to finish out the season.
Thanks for all the input guys.
79 LTD B3
