Slipping while in second gear
- jbrewer73
10 Aug 2009 20:44
I have a 1980 LTD1000. The problem im having is that when I shift it into second and beging to wind it out it will cut in and out. It acts like your pulling the clutch in and out while revving it up in second. It only does it in second gear. Sometimes it wont do it at all. It doesnt fall out of gear though. Is this shift forks or possibly clutch plates????
Thanks
Thanks
- bountyhunter
Re: Slipping while in second gear
10 Aug 2009 22:18
A slipping clutch usually slips worse in first gear if you get on it hard. Don't know why a clutch would only slip in second gear.
- gfmarsh
10 Aug 2009 23:36
What kind of oil are you using?
1981 Kawasaki KZ1000 J, bought in 1991
2004 ZZR1200, bought in 2005
Have also owned a 1981 KZ550 (first bike), 1984 Ninja 900, 1978 RD400, and a 1982 BMW R65
- donthekawguy
11 Aug 2009 00:06
Mine does the same thing. I just figured a new clutch would fix it. I still need to put the clutch in.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- KZ250LTD
11 Aug 2009 01:06
You'll often see bikes that have been bagged to death that pop out of second due to bent forks... not sure why it would cut in and out though
79 KZ1000ST
Past:
Many.
Past:
Many.
- jbrewer73
- gfmarsh
12 Aug 2009 11:47
As long as it's motorcycle oil then you can rule that out as a cause. I tried running Mobil 1 once and my bike ran like crap; slipped clutch, and would pop out of gear while on throttle. I quickly changed it out and cannot remember why I even tried to do that in the first place. When I went back to synthetic motorcycle oil the problem disappeared entirely.
- saxjonz
- KawboyZ
12 Aug 2009 16:34
Sounds like bent shift forks or worn gear dogs from abuse. It usually starts slowly and then progresses. If you ride it hard in second gear it will do that. Means you will have to tear it down to fix that problem. I have done that in two of my bikes. My midnight special started to do it slowly as if it had a hiccup and then gradually it would not pull at all in second gear. My zr1100 had that problem it went at 10k rpms while I was racing my nephew with his 600. Felt like I hit a pothole really hard and after that she was gone.
jbrewer73 wrote:
Thanks
79 LTD B3
- brianrae33
13 Aug 2009 07:56
take the engine out of the frame..flip it over and drop the oil pan..you can visually inspect the dogs on your gears that way..if they look ok you can replace the sfift forks without slippting the cases..
1982 kz1000ltd
- saxjonz
- KawboyZ
15 Aug 2009 21:02
Yeah that sounds right.
79 LTD B3
16 Aug 2009 04:34
jbrewer73 wrote:
If not already done, would perform clutch pushrod adjustment.
Good Luck!
...1980 LTD1000...shift it into second and beging to wind it out it will cut in and out. It acts like your pulling the clutch in and out while revving it up in second. It only does it in second gear. Sometimes it wont do it at all. It doesnt fall out of gear though. Is this shift forks or possibly clutch plates???? Thanks
Good Luck!
- jbrewer73
16 Aug 2009 19:08
Im gonna wait til it gets a little colder here in Chicago to do this project. She has been riding pretty good lately. Trying to finish out the season.
Thanks for all the input guys.
