Slipping while in second gear
- jbrewer73
Thanks
- bountyhunter
- Thank you received: 337
- gfmarsh
1981 Kawasaki KZ1000 J, bought in 1991
2004 ZZR1200, bought in 2005
Have also owned a 1981 KZ550 (first bike), 1984 Ninja 900, 1978 RD400, and a 1982 BMW R65
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- jbrewer73
- gfmarsh
- saxjonz
- KawboyZ
- Thank you received: 76
jbrewer73 wrote:
I have a 1980 LTD1000. The problem im having is that when I shift it into second and beging to wind it out it will cut in and out. It acts like your pulling the clutch in and out while revving it up in second. It only does it in second gear. Sometimes it wont do it at all. It doesnt fall out of gear though. Is this shift forks or possibly clutch plates????
Thanks
79 LTD B3
- brianrae33
1982 kz1000ltd
- saxjonz
- KawboyZ
79 LTD B3
- Thank you received: 2098
...1980 LTD1000...shift it into second and beging to wind it out it will cut in and out. It acts like your pulling the clutch in and out while revving it up in second. It only does it in second gear. Sometimes it wont do it at all. It doesnt fall out of gear though. Is this shift forks or possibly clutch plates???? Thanks
If not already done, would perform clutch pushrod adjustment.
Good Luck!
- jbrewer73
Thanks for all the input guys.
