All fluids
09 Aug 2009 05:48 #312638 by ohioKZnut
All fluids was created by ohioKZnut
Ok,Ive tried looking up on internet and got manuals.
Could somebody tell me all the fluids to check on my KZ650 1978.I know how to check the oil,and master cylinder.But is there any other fluids im missing?I just want to make sure i keep up to par,maybe even a website of the engine and where stuff is.Thank you:)
78 KZ 650
09 Aug 2009 05:54 #312640 by Patton
Replied by Patton on topic All fluids
Also battery levels (where applicable).
And fork oil (per maintenance schedule).
Good Luck! :)
09 Aug 2009 07:02 #312649 by ohioKZnut
Replied by ohioKZnut on topic All fluids
Ok ,thank you,wasnt sure if there was gear oil and stuff.
78 KZ 650
09 Aug 2009 07:56 #312658 by JMKZHI
Replied by JMKZHI on topic All fluids
The engine & transmission use the same oil.
A good oil to use is Shell Rotella-T 15W40.
Be sure to use distilled water in the battery.
As for the forks, you'll probably find that they're overdue for service - old oil is greyish black. The manual probably specifiec 10W fork oil, but 15W might be a better idea.
09 Aug 2009 09:23 - 09 Aug 2009 09:30 #312670 by bill_wilcox100
Replied by bill_wilcox100 on topic All fluids
ohioKZnut, here are a few Fluid Specifications for all years of the KZ650:
Descriptions...........Specification
Fuel Service Level......2-3 mm below carb bowl mating surface.
Oil Type.......................SAE 10W-40.
Oil Quantity.................(change) Approx. 3.2 liters.
Oil Quantity.................(Filter Change) Approx. 3.8 liters.
Fork Oil Weight...........15W.
You can find more KZ650 information here: Link
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 09 Aug 2009 09:30 by bill_wilcox100.
09 Aug 2009 12:05 #312690 by ohioKZnut
Great ,thanks for the info,how about links to picture diaphrams,and how often i should change oil,and then filter.Im running 4 into 1 pipe and not sure if the ignition and coils are upgraded.Im trying to learn my bike by examining,but pictures of what is what would greatly help.Ive read the thread on "what kind of oil is everybody running." but couldnt see whats best and how often.
78 KZ 650
09 Aug 2009 15:11 #312703 by Patton
No eBay APP ID and/or Cert ID defined in Kunena configurationWould consider obtaining an official Kawasaki service manual. It's one of the best investments for a KZ owner. Here's one of several currently listed on ebay. Or just search for "KZ650 manual" on ebay.
Good Luck! :)
09 Aug 2009 17:41 #312753 by mzandmz
Replied by mzandmz on topic All fluids
Dont forget the antifreeze!(coffee)About two cups :laugh:
New to Family, 1979 KZ440 LTD
09 Aug 2009 17:47 #312760 by TerryK
Replied by TerryK on topic All fluids
Mine performs much better when I add 2 or 7 bottles of beer.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
10 Aug 2009 08:43 #312934 by rstnick
Replied by rstnick on topic All fluids
There's a Haynes service manual download available here:
forums.kz650.info/index.php?board=19.0
and free electronic manuals here, top post:
forums.kz650.info/index.php?board=29.0
Service schedule:
img.photobucket.com/albums/v494/rstnick/Maintenanceschedule.jpg
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
10 Aug 2009 14:08 #312976 by ohioKZnut
WOW,thank you so much,very helpfull.
78 KZ 650
  • Kawickrice
10 Aug 2009 15:02 #312979 by Kawickrice
Replied by Kawickrice on topic All fluids
Don't forget to check the blinker fluid every 4000 miles also. B)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
