- Thank you received: 5
All fluids
- stardon
10 Aug 2009 15:22 #312981
by stardon
Replied by stardon on topic All fluids
Be sure to drain the bladder tank before every ride.
- Thank you received: 2829
10 Aug 2009 16:12 #312985
by 650ed
Replied by 650ed on topic All fluids
Don't forget to lube the drive chain about every 300 miles and hit the swingarm grease fitting when you change the oil. Of course, the steering stem bearings should be greased, but you may want to wait until you can afford to spend a couple days removing & replacing the front forks to do this, and you may want to replace the original ball & race bearings with tapered bearings once you get into this job. Don't even think about doing this job without the correct Factory shop manual. Ed
- ohioKZnut
10 Aug 2009 18:08 #313007
by ohioKZnut
78 KZ 650
Replied by ohioKZnut on topic All fluids
yea,i just finished greasing the baffle bearings,,har,har
78 KZ 650
