Need Help post re-build!!! Desperate!!
  • IowaKZ
  • Topic Author
  • '80 G1 Classic
06 Aug 2009 19:13 #312101 by IowaKZ
OK, I am fried. I just finished replacing my valve seals which was a big job for me. It took me almost a month because I took a vacation in the middle. I spent a lot of time cleaning and painting as I went. I finally got it all together tonight, checked everything (I thought) 2x.
when I finally went to start it, I decided to use the kick to save on the battery, and I expected it to start hard until the gas made it through the pump and the injectors.
However, when I pull in the clutch there is no compression or back pressure on the kick start. If I just kick it over, without the clutch, then I can hear everything moving. when I try the starter, it all turns over, but, of course, it doesn't start. i didn't try very long to save the battery.
there must be a wire I missed or something that got disconnected when I was working. My mind is fried right now because I have been really pushing to get this done this week before the kids go back to school (transportation issues).
Any thoughts on where to start looking? Thanks in advance. There are several cold beers waiting in Iowa for the help.
Dale
1980 G1 Classic
Bettendorf, Iowa
06 Aug 2009 19:35 #312109 by Sandy
Replied by Sandy on topic Need Help post re-build!!! Desperate!!
With the clutch lever pulled in,you're disengaging the clutch from the engine,and the kickstarter grabs at the clutch,so...you won't be turning the engine over with the lever pulled in.
Have you checked to see if you're getting spark to the plugs?
1977 KZ1000 A-1
06 Aug 2009 19:40 #312110 by TerryK
Replied by TerryK on topic Need Help post re-build!!! Desperate!!
Check all the basics. Fuel delivery, compression, spark. If you have them all, it should go. Missing one, there's your problem. Don't over think it. Keep it simple and you will find the problem.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
06 Aug 2009 19:49 #312113 by Link14
Replied by Link14 on topic Need Help post re-build!!! Desperate!!
Dale,
I've been there chasing electrical gremlins around in circles....If you're fried, drink one of those beers, go to bed and tackle it when you're fresher.
Good luck!
  • IowaKZ
  • Topic Author
  • '80 G1 Classic
06 Aug 2009 19:58 #312115 by IowaKZ
Replied by IowaKZ on topic Need Help post re-build!!! Desperate!!
Link14 wrote:
Dale,
Good luck!
sounds like a plan. I have all weekend to figure it out.
I thought that the clutch had to be pulled in to start it. Like a lock out? Is that only for the electric start?
1980 G1 Classic
Bettendorf, Iowa
06 Aug 2009 20:02 #312116 by Sandy
Yes,electric start only. B)
1977 KZ1000 A-1
06 Aug 2009 20:13 #312118 by Mark Wing
Replied by Mark Wing on topic Need Help post re-build!!! Desperate!!
I'd check the coil leads, good luck.
Mark
Yorba Linda Cal.
  • IowaKZ
  • Topic Author
  • '80 G1 Classic
06 Aug 2009 20:18 #312120 by IowaKZ
Replied by IowaKZ on topic Success, I feel like a dork
Ok, I know I should have waited but I couldn't.
a few kicks and the electric start, back and forth, and it finally started. :woohoo:
then it over reved and I had to kill it. I need to set the idle, obviously.
I just didn't have enough fuel in the system with the pump, the manifold and the injectors.
I feel like a dork. I guess it's been a while since I used the kick start....:blush:
thanks again. Beers all around. Call me when you're ready.
(big sigh of relief).
1980 G1 Classic
Bettendorf, Iowa
06 Aug 2009 20:23 #312121 by Sandy
Replied by Sandy on topic Success, I feel like a dork
I'll have a rum and coke please. :laugh:
Glad to hear you got it running...now the fine tuning...
1977 KZ1000 A-1
06 Aug 2009 20:23 #312122 by Mark Wing
Replied by Mark Wing on topic Success, I feel like a dork
Cool, glad you got it started.
Mark
Yorba Linda Cal.
  • IowaKZ
  • Topic Author
  • '80 G1 Classic
06 Aug 2009 20:30 #312123 by IowaKZ
you got it.
I love this site.
thanks guys.
1980 G1 Classic
Bettendorf, Iowa
06 Aug 2009 21:08 #312128 by mzandmz
Replied by mzandmz on topic Success, I feel like a dork
I have a question? How do you kick start a 77 KZ650. I feel like a dork but cant figure it out.
New to Family, 1979 KZ440 LTD
