- Thank you received: 5
Need Help post re-build!!! Desperate!!
- IowaKZ
- '80 G1 Classic
when I finally went to start it, I decided to use the kick to save on the battery, and I expected it to start hard until the gas made it through the pump and the injectors.
However, when I pull in the clutch there is no compression or back pressure on the kick start. If I just kick it over, without the clutch, then I can hear everything moving. when I try the starter, it all turns over, but, of course, it doesn't start. i didn't try very long to save the battery.
there must be a wire I missed or something that got disconnected when I was working. My mind is fried right now because I have been really pushing to get this done this week before the kids go back to school (transportation issues).
Any thoughts on where to start looking? Thanks in advance. There are several cold beers waiting in Iowa for the help.
Dale
1980 G1 Classic
Bettendorf, Iowa
- Sandy
- Fly High,Tony
- Thank you received: 13
Have you checked to see if you're getting spark to the plugs?
1977 KZ1000 A-1
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Link14
- Thank you received: 6
I've been there chasing electrical gremlins around in circles....If you're fried, drink one of those beers, go to bed and tackle it when you're fresher.
Good luck!
- IowaKZ
- '80 G1 Classic
Dale,
Good luck!
sounds like a plan. I have all weekend to figure it out.
I thought that the clutch had to be pulled in to start it. Like a lock out? Is that only for the electric start?
1980 G1 Classic
Bettendorf, Iowa
- Sandy
- Fly High,Tony
1977 KZ1000 A-1
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- IowaKZ
- '80 G1 Classic
a few kicks and the electric start, back and forth, and it finally started. :woohoo:
then it over reved and I had to kill it. I need to set the idle, obviously.
I just didn't have enough fuel in the system with the pump, the manifold and the injectors.
I feel like a dork. I guess it's been a while since I used the kick start....:blush:
thanks again. Beers all around. Call me when you're ready.
(big sigh of relief).
1980 G1 Classic
Bettendorf, Iowa
- Sandy
- Fly High,Tony
Glad to hear you got it running...now the fine tuning...
1977 KZ1000 A-1
- Mark Wing
Mark
Yorba Linda Cal.
- IowaKZ
- '80 G1 Classic
I'll have a rum and coke please. :laugh:
you got it.
I love this site.
thanks guys.
1980 G1 Classic
Bettendorf, Iowa
- mzandmz
New to Family, 1979 KZ440 LTD
