Will not restart when hot
- EgoCrusher
Matt
Mantua, New Jersey
- Old Man Rock
- Thank you received: 225
Once started and during a ride, are you noticing any difference in performance such as acceleration, back fire or exhaust popping during deceleration, lack of power, flat spot/lining on power, running sluggish etc....
Or coming to an intersection, pinging noises, have to keep on the throttle to keep it running, slow take off's from dead start or does it sluggish then all of a sudden run like a raped ape etc....
When you say hot, normal temps or are you noticing more than normal heat build ups?
On cold or hot start up, smoke out the exhaust?
Ignition timing good?
Valve clearances good?
Spark Plugs look good?
Battery voltage good?
Proper voltage @ coils?
etc....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- MFolks
- Thank you received: 540
1. Valve clearances,metal expands when hot,possibly a valve or two partially open letting compression out.
2. Sparkplug wires and caps age and loose conductivity.Replace and try again.
3. Ignition coil(s) fail when hot. Where the coils are mounted can heat stress them causing failures.
4. Check all heavy duty battery connections for tightness and traces of corrosion. All must be clean and tight.
- EgoCrusher
- EgoCrusher
Several places to check:
All wire and plugs checked and ground wire replaced.
- Old Man Rock
Assuming all other mentioned items are within specification (please insure you measure/adjust to specifications) before going after your carbs... Best guess at this time is carburetor issues...
Most likely running lean thus over heating engine...
Either main/needle jets not the right size or gunked up etc...
I don't know your carbs (someone here should) so if the needle jets are the clip version, you need to richen it up by changing the clip position. If all is working, you should hear a difference in the exhaust popping...
Again, assuming they're the correct jet but just wrong clip position...
What do the insulators and end of thread base look like on your spark plugs?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
- Thank you received: 337
That sounds like a very lean pilot jet, needle set too lean, or a vacuum leak. Either will make it hard starting. The easy start cold is probably because you can use the choke which riches it up.There is no difference in performance. The bike does back fire realy bad during deceleration. It is a little sluggish on take offs then it will just pull the wheel off the ground. It does it at norm temps of riding.
Does the bike have aftermarket pipes and/or pod air filters?
- EgoCrusher
is the pilot jet the one that is on the top of the carb motor side? The pipe have been gutted by the last owner and it has the stock air box.
- EgoCrusher
"The bike does back fire really bad during deceleration. It is a little sluggish on take offs then it will just pull the wheel off the ground."...
OMR
the jets are120. And I need to buy a book for the bike unless someone has a PDF file they would like to share.
- bountyhunter
Not sure where they are on yours. You can look up the carb diagram on babbittsonline.com and it lists all the parts.bountyhunter wrote:
If the baffle is out of the pipe, it could be running very lean.
- OKC_Kent
- Thank you received: 20
Here is a manual link courtesy of loudhvx.
home.comcast.net/~loudgpz/KZ5mnl.pdf
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- KZ1979LTD
