Will not restart when hot
- EgoCrusher
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Before getting into possible theories of what may be the cause....
Once started and during a ride, are you noticing any difference in performance such as acceleration, back fire or exhaust popping during deceleration, lack of power, flat spot/lining on power, running sluggish etc....
Or coming to an intersection, pinging noises, have to keep on the throttle to keep it running, slow take off's from dead start or does it sluggish then all of a sudden run like a raped ape etc....
When you say hot, normal temps or are you noticing more than normal heat build ups?
On cold or hot start up, smoke out the exhaust?
Ignition timing good?
Valve clearances good?
Spark Plugs look good?
Battery voltage good?
Proper voltage @ coils?
etc....
OMR
Jumped on that one! :laugh: All good info!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
Ok so i put new spark pug wires on the bike and my voltage went up . But still when the bike runs for 2 min and i try to give it gas it bogs out and will not restart till it is cold.
Sounds to me like too rich on pilot.
Will it start if you close the choke fully and crack the throttle slightly?
Once hot, pull a plug. Reconnect it to the wire, and hold it against the head whilst cranking. Is the spark fat and blue and consistant? Or yellowish, dark and intermittant?
*** Carful not to ignight gas vapor being expelled by cylinder! ***
Good Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
- EgoCrusher
- EgoCrusher
Good Luck!
I tried every thing it just will not restart when hot, and I will test the spark in the morning and let you know.
- loudhvx
- Thank you received: 1616
The hot restart issue can be several things, but first thing to check would bevalve clearance. You want to make sure the motor is right, then ignition, then mess with the carbs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- EgoCrusher
