- Thank you received: 92
Maiden Voyage, have noise when hot...
- Tyler
01 Aug 2009 14:03 #310772
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic Maiden Voyage, have noise when hot...
I re-verified the timing and it is spot on. Then I reset the cam chain and locked the tensioner with a longer bolt to rule out that as an issue. Took it for a ride and the noise came back after a few minutes. I am convinced it is valves so I will have to re-check the clearences and look for anything obvious. It runs well, VERY well. Holy crap its got some power...
- TeK9iNe
- What did you do!?!
- Thank you received: 28
02 Aug 2009 20:50 #310994
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Maiden Voyage, have noise when hot...
The valves will always have some faint ticking noise, even when at the smallest in-spec gap.
It's just the nature of flat tappet engines...
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Tyler
03 Aug 2009 00:17 - 03 Aug 2009 00:18 #311055
by Tyler
I found the culprit, my valve clearences were all perfect. OldManRock was close with his guess of the top chain guide. I modified the factory guide to use the sprocket from an APE guide. The head of the fastener I used had little clearence to the valve cover and I can see a small cresent shapped mark where it has been rattling against it. I think as the rubber mounts got warmer they got more pliable and eventualy the vibration started tapping the valve cover. That was the metallic click I heard. I clearenced the cover a bit and ground the bolt head down some. If my theory is right I shoudln't have the noise when I drive it tomorrow.
Last edit: 03 Aug 2009 00:18 by Tyler.
- fixer5000
- Thank you received: 5
03 Aug 2009 01:08 #311085
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Maiden Voyage, have noise when hot...
is that bearing running on a plain old socket caps shaft? id almost bet that sprocket is dancin round on there too... you need a shoulder bolt in there. they have a much lower profile head and a polished shaft surface. i believe theyre also harder steel. search for shoulder bolt on the net youll see what i mean
massachusetts
- fixer5000
03 Aug 2009 01:16 #311088
by fixer5000
massachusetts
massachusetts
- Tyler
03 Aug 2009 06:42 - 03 Aug 2009 06:44 #311119
by Tyler
Nope not an issue, there is a precision machined shaft the sprocket is rolling on, the bolt just sandwiches it between the sides of the mount. It is no differnt than the factory part in that respect only Kawasaki used a big rivet to do the same.
Last edit: 03 Aug 2009 06:44 by Tyler.
- Tyler
03 Aug 2009 18:35 - 03 Aug 2009 18:35 #311303
by Tyler
Looks like I resolved the problem. The APE chain rollers do seem louder. The Kerker kinda drowns it out though
Last edit: 03 Aug 2009 18:35 by Tyler.
- arai59
- Banned
- Thank you received: 1
03 Aug 2009 18:43 #311310
by arai59
Replied by arai59 on topic Maiden Voyage, have noise when hot...
Thats great you narrowed your problem. Very satisfying. Once my brakes didn't work very well so I made my horn louder.:laugh:
- fixer5000
04 Aug 2009 12:51 #311520
by fixer5000
massachusetts
arai59 wrote:
made me chuckle and it actually makes some sense lol good one arai59!!
massachusetts
