- Thank you received: 92
Maiden Voyage, have noise when hot...
- Tyler
Anyway I have a 700cc Wiseco kit and a dyna ignition. So my initial thoughts are my timing could be a tad too advanced and I am hearing pinging. OR my timing chain is getting slack when warm, or I messed up a valve shim and have too much play in one.
What do you all think, what could be a problem when warm? It sounds great when I first start it. I only drove it down the street and back maybe a mile and a half total.
"74 Yamaha DT 400 Enduro
- Old Man Rock
- Thank you received: 225
Timing chain adjusted properly?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Tyler
- arai59
- Banned
- Thank you received: 1
Its a metallic sound, I don't think it is an exhaust leak. Valves wouldn't make more noise when hot would they? I would think they would quiet down if anything.
Maybe a tight valve.
- bountyhunter
- Thank you received: 337
- bountyhunter
It's possible a loose one would be quieter with colder (thicker) oil.Its a metallic sound, I don't think it is an exhaust leak. Valves wouldn't make more noise when hot would they? I would think they would quiet down if anything.
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
Exhaust leaks at the header sound like a "crack-crack-crack" sound that gets louder as you open the throttle.
- Thank you received: 2098
Oil is thicker when cold, and providing more "padding" on cam lobes.
Am thinking more noise upon reaching normal operating temp where oil is thinner.
With hydraulic valve lifters (not KZ), cold clicking is sometimes heard until the oil warms and thins to fill the lifter chambers.
Good Luck!
- Old Man Rock
Don't get me wrong here, top quality but they do make a little more noise then the OEM idler assembly which threw me off as well on my build...
Not so much as clicking, clacking, slapping or what ever sound we're all going to debate over.... Just a little more noisier...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I guess it depends on the ear. Loose valves sound like a click to me, clacking is usually a loose chain hitting something.
+1 Could'nt have said it better
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Tyler
