- Thank you received: 43
Stripped Exhaust Threads
- 79MKII
- Love Them Kaws!
31 Jul 2009 07:44 - 31 Jul 2009 07:49 #310533
by 79MKII
The Kaw List:
Replied by 79MKII on topic Stripped Exhaust Threads
Go with the 8mm studs just like the factory. Should be plenty left to tap if it was a 6mm hole that stripped. Should be able to do everything right on the bike too. Good luck and keep us posted - with pictures!
The Kaw List:
Last edit: 31 Jul 2009 07:49 by 79MKII.
- kawasakibikefan
- Riding is a passion most do not understand.
31 Jul 2009 07:48 #310536
by kawasakibikefan
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Replied by kawasakibikefan on topic Stripped Exhaust Threads
I was wondering about studs. Do studs make it easier or harder to install the exhaust? The last time I did it was a pain even with 2 people. The rubber band trick and grease on gasket was a miracle though.
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- 79MKII
- Love Them Kaws!
31 Jul 2009 07:51 #310537
by 79MKII
The Kaw List:
I think the studs are MUCH easier. I think slipping the collar over the studs is much easier than trying to get everything lined up and then a bolt through and started into the threads. You'll be happier with the studs for sure. You might want to buy the nuts too if Z1 carries them.
The Kaw List:
- Old Man Rock
- Thank you received: 225
31 Jul 2009 08:06 #310538
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Stripped Exhaust Threads
Trick to hold the copper gaskets in place I learned from crusty ole Plummen...
Permatex Copper... coat the flat side of the copper gasket with some permatex, insert into place... They will bond and hold while your inserting your split collars and collars!
This also acts as a sealer of sorts, no exhaust leaks!
See, we all new why we put up with his crap for something... :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- JMKZHI
- Thank you received: 48
31 Jul 2009 09:28 #310548
by JMKZHI
Replied by JMKZHI on topic Stripped Exhaust Threads
Or wheel bearing grease - just dab some on the gaskets.
- kawasakibikefan
05 Aug 2009 14:46 - 05 Aug 2009 14:52 #311816
by kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Here is a picture of the exhaust threads. Is this enough material that I would be safe to convert to 8mm exhaust studs?
farm3.static.flickr.com/2487/3793526788_7997a03645.jpg
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Last edit: 05 Aug 2009 14:52 by kawasakibikefan.
- MFolks
- Thank you received: 540
05 Aug 2009 15:28 #311819
by MFolks
Replied by MFolks on topic Stripped Exhaust Threads
The exhaust collars will have to be drilled for 8mm studs. Be careful to not go any deeper in the engine when drilling and tapping for the 8mm studs. I understand an oil gallery is right behind where the studs go.
I believe a 7mm drill bit is the correct size for the 8mm tapped hole for the studs. Your tap should be a 8 x 1.25 in size. A drill stop should be used to prevent drilling too deep. Using a fixture or drill bushing will keep the tap at 90 degree angle to the engine.
If you don't feel confident in doing the drilling and tapping,I'd suggest calling the bike shops and see who they use for this kind of repair.
- 79MKII
- Love Them Kaws!
05 Aug 2009 17:22 #311845
by 79MKII
The Kaw List:
Here's a link to a chart (hopefully correct) but MFolks is right, 6.9mm to be exact.
www.boltdepot.com/fastener-information/M...-Tap-Drill-Size.aspx
The Kaw List:
- kawasakibikefan
05 Aug 2009 17:26 #311847
by kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Ok looks like I will tackle this during the winter. To much good weather to take motor off of bike right now! Thanks for the info.
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- TerryK
- Thank you received: 3
05 Aug 2009 18:07 #311856
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Stripped Exhaust Threads
I've done the drill and tap to 8mm fix many times, and if you are careful and take your time, you can do it with the motor in the bike. Just stuff rags in the exhaust ports and use lots of cutting oil.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- kawasakibikefan
06 Aug 2009 13:36 #312044
by kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Yeah it is tempting to get it out of the way right now but I do not want to have to be "extra" careful because I tend to screw something up. I think I will do the easier way and not have to worry about it so much. So far no exhaust leak has occured so I am not in a big rush.
The plus side to removing the engine is I get to degrease it and also get to repaint frame.
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
