Stripped Exhaust Threads
- kawasakibikefan
- Riding is a passion most do not understand.
30 Jul 2009 14:12 #310401
by kawasakibikefan
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Stripped Exhaust Threads was created by kawasakibikefan
I have a 75 Z1B with the bolt holes in the head stripped. What would be the best thing to do with this? I have tried to tap with the same thread but it was a no go. Only a few bolt holes are stripped. I have now had 2 bolts fall out going down the road. The first time I noticed because I could here an exhaust leak. This time the seal is holding up and no leak. Should I take it to a machine shop and have them look at a solution or is this something an average mechanic can do at home?
What I thought would be my next option is to drill out threads tap for a different size and use a bigger bolt but I do not know if the aluminum head can take that. Could this be a possibility (seems like an easy task for me to do...)?
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- MFolks
- Thank you received: 540
30 Jul 2009 14:45 #310406
by MFolks
Replied by MFolks on topic Stripped Exhaust Threads
I'd call around at machine shops and get some prices for Heli-Coils or Time-Serts:
www.timesert.com/html/mtrcsert.html
Ask at the bike shops who they trust for this kind of work.
- kano
- Not Another Bloody Limey!
30 Jul 2009 15:12 - 30 Jul 2009 15:13 #310410
by kano
Replied by kano on topic Stripped Exhaust Threads
let me save you time and money bro!
i bought the time sert kit
first kit was wrong i needed
the big serts for my exhaust studs
as they had been heli coiled 19 yrs earlier
and lost their thread again. :dry:
i spent $80 bucks on each kit
and as i was drilling the first hole i chipped out half the side, :blush: sat down had a beer!
in the end after good advise from fellow members
i took the motor out, :S
and had 2 holes welded up and re tapped by a welder
cost me $200 for the guy to do it and unless you looked real close you could never tell,
on the plus side i had motor pressure washed and blasted
while it was out, all ready for a fresh coat of paint.
its the only way to go get it welded up and re tapped..
Last edit: 30 Jul 2009 15:13 by kano.
- kawasakibikefan
30 Jul 2009 18:03 #310446
by kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Replied by kawasakibikefan on topic Stripped Exhaust Threads
I do not know how I forgot about helicoils. My school has a set and so does my dad. I guess I will probably do that because lets face it $200 is a lot. I will probably do something different like kano said when I rebuild the engine. I just do not want to be out of service that long. I just need it to last till this years winter or next years winter. That is when I plan to rebuild my engine on this bike and another bike.
Or another question. Should I worry about an exhaust leak if it does occur? I mean it is just an unwanted noise or is it more than that?
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- MFolks
30 Jul 2009 18:41 #310454
by MFolks
Fresh exhaust crush gaskets will end your worry.
www.z1enterprises.com
can get the Suzuki ones that are a little thicker than the Kawasaki's.
- Thank you received: 2098
30 Jul 2009 18:53 - 05 Aug 2009 18:14 #310458
by Patton
Replied by Patton on topic Stripped Exhaust Threads
Z1~KZ900 used 6mm exhaust studs.
1977 KZ1000 changed to 8mm exhaust studs, which then continued as the norm.
Perhaps there's enough metal to re-tap for the larger 8mm studs.
Z1E carries both sizes.
Click here for link to > 8mm exhaust studs from Z1E
It would be okay to keep using the 6mm studs that aren't stripped.
Good Luck!
Edit -- with any re-threading, be careful about the depth so as not to penetrate an oil passage. Just go same depth as oem hole, and no deeper.
Good Luck!
Last edit: 05 Aug 2009 18:14 by Patton.
- kawasakibikefan
30 Jul 2009 19:48 #310472
by kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
O I forgot to mention it is not a stock exhaust. There are no studs. It is a 4 into 1 but I have no idea what one it is. I just use 6mm screws. Should I put studs back into it?
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
30 Jul 2009 20:18 - 30 Jul 2009 20:19 #310476
by Patton
Am thinking MaKaw used studs (not bolts) for good reason.
Seems that steel bolt being frequently torqued into and out of aluminum threads adds more risk toward stripping soft aluminum threads.
Whereas a semi-permanent steel stud implanted in an aluminum base thereafter involves a steel nut on a steel stud without much stress on the aluminum base.
Same reason for cylinder studs and head nuts instead of long bolts through head and cylinders into aluminum cases. It's with steel bolts screwing into aluminum where problems often occur, such as cam cap bolts so readily stripping the aluminum head threads.
Imo, using bolts (instead of studs) to attach the headers is asking for trouble, some of which is now being experienced. :pinch:
Good Luck!
Good Luck!
Last edit: 30 Jul 2009 20:19 by Patton.
- DrWhizBang
31 Jul 2009 05:28 #310507
by DrWhizBang
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
Replied by DrWhizBang on topic Stripped Exhaust Threads
I'm with Patton on this. In fact, some PO of my bike had used bolts in place of studs, and I ended up with a couple of stripped holes. By replacing the bolts with studs I was able to screw them all the way into the head in the stripped holes and avoid any repairs to the threads at all. That might work for you too.
- Old Man Rock
- Thank you received: 225
31 Jul 2009 06:09 #310513
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Stripped Exhaust Threads
can try one more thing...
The z1 and kz900 exhaust studs are 6mm... Yours is stripped.
Tap the holes for 8mm studs and replace...
RedLine Cycle has the studs just for this... Hell, you ccan probably get some grade 8 studs at any automotive parts store for that matter or ACE hardware..
Just a thought...
OMR
redlinecycle.com/flanges2.html
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
- Thank you received: 235
31 Jul 2009 06:24 #310517
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Stripped Exhaust Threads
you may be able to do one of the above fixes by either a longer threaded stud or trying to insert a coil......i am another member who wasted time=$...and a good chunk of real $....by spemding ten on this and 18 on this and 23 on that and 5 on this ...ect.....ect...
in the end it all sucked way hard.....i decided to pull the motor....1 hr.....and threw it in a wheelbarrel and sprayed gunk-engine brite and a lot of pressure washing...it was the ticket...then threw it on a big towel in my beater civic,,,,took it to a local welder with references...he used to have 500 triple turns out.....he welded the holes closed and re-set my studs......1 hr to drop the motor in and now i can tighten my header sweet,,,,,,imo....this is the only way.....everything else is a shot at best....100$ is what my guy got for it.....plus i now have a good welder dude to go to....good luck.....let us know like kano and i did when repaired....thanks craig
p.s i don't miss the welders 100 one bit...i was however stressing for two weeks back then though....100 was easy compared to having no bikey to rickey
1976 KZ900
2003 ZX12R
2007 FZ1000
- JMKZHI
- Thank you received: 48
31 Jul 2009 07:15 #310530
by JMKZHI
Replied by JMKZHI on topic Stripped Exhaust Threads
Z1Enterprises.com has exhaust studs.
