- Thank you received: 104
Frozen KZ 1000 engine
- PLUMMEN
01 Aug 2009 14:02 #310771
by PLUMMEN
Replied by PLUMMEN on topic Frozen KZ 1000 engine
dump gas/trans fluid down plug holes .if its stuck that good i think id use the kick starter to try and work it over by hand
- Duck
- e vica na i sau na ga
01 Aug 2009 14:44 - 01 Aug 2009 14:44 #310786
by Duck
Replied by Duck on topic Frozen KZ 1000 engine
MMO or ATF
Plugs out...watch that you don't strip the head.
Pour liberal amount in each jug.
Let her sit a bit.
Put in 2nd or 3rd, get on the saddle, and rock back and forth for 5 minutes. If no go, wait a few hours and try again. If no go, wait a day , add a little more ATF/MMO and try again. Don't give up for at least a week-10 days.
Let her sit a bit.
Last edit: 01 Aug 2009 14:44 by Duck.
- TerryK
- Thank you received: 3
03 Aug 2009 18:01 #311299
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Frozen KZ 1000 engine
Isn't the point moot. A frozen engine will have to be torn down anyway. There will be serious damage if there is enough water or corrosion in the engine to freeze it so why not just do it the right way with a tear down?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- will61310
- Thank you received: 6
03 Aug 2009 18:09 #311301
by will61310
...1980 LTD 1000...
Replied by will61310 on topic Frozen KZ 1000 engine
previous owner couldve fried the engine before you got the bike?? Ive got a 1000 engine thats been sitting on a garage floor 12 yrs i just got back and took the plugs out and it kicks over by hand
...1980 LTD 1000...
- roy-b-boy-b
- Thank you received: 103
03 Aug 2009 19:18 #311329
by roy-b-boy-b
Replied by roy-b-boy-b on topic Frozen KZ 1000 engine
My engine was sitting for years too and it wasn't stuck. Inside the whole time.
I had a friend that bought a V65 that had been sitting under the eve of a house for six months and it was stuck. They tood a wrench on both sides of the engine and got it unstuck with no ill effects. Roy
- Duck
03 Aug 2009 22:15 #311411
by Duck
TerryK wrote:
Only if it smokes and when you do want to tear it down, it's tough to get jugs off when they're stuck to the pistons. mmmm jugs mmmm
- nads.com
- Thank you received: 20
04 Aug 2009 00:41 #311433
by nads.com
Replied by nads.com on topic Frozen KZ 1000 engine
if it doesnt have the power it should compression rings could be stuck, and may break , compression test son.
- TerryK
04 Aug 2009 13:29 #311528
by TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Good compression, no smoke, regardless, if it's stuck, it's coming apart.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
