Frozen KZ 1000 engine
- fandango
30 Jul 2009 11:28 #310380
by fandango
Frozen KZ 1000 engine was created by fandango
I have a frozen 1980 kz1000 engine still in the bike.The PO said it`s been in a storage for 10 years.His explanation seemed plausible because the carbs are frozen,brakes are frozen too.
I poured oil to the head and let it sit for a couple days.I put it in gear and try to loosen up.(I took off the brakes,so it would be free to roll.)Nothing happening.You guys have some ideas what else should I try without taking apart?
- hugo
- '92 Zephyr 750
- Thank you received: 71
30 Jul 2009 11:45 #310384
by hugo
Replied by hugo on topic Frozen KZ 1000 engine
It may be silly, but I take it that you tried, in neutral, turning it by hand applying a wrench to the crankshaft, and you removed the spark plugs to eliminate compression. Right?
- KawiConvert
- Thank you received: 4
30 Jul 2009 11:47 #310385
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Frozen KZ 1000 engine
I'd try some PB or other rust eater. If all else fails it may be time to pop the top and tap them lightly with a rubber mallet.
- fandango
30 Jul 2009 12:27 #310392
by fandango
Replied by fandango on topic Frozen KZ 1000 engine
Yes spark plugs are out to eliminate comp.I read somewhere seafoam may help.I will pop the top see what is going on there.
- roy-b-boy-b
- Thank you received: 103
30 Jul 2009 15:10 #310409
by roy-b-boy-b
Replied by roy-b-boy-b on topic Frozen KZ 1000 engine
I would try and get it broke loose before tearing it down. Roy
- cmmman
- kztee
- TeeRoy
30 Jul 2009 16:59 #310431
by kztee
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
Replied by kztee on topic Frozen KZ 1000 engine
Not that I am recommending this but...
A friend of mine bought a siezed bike from a local shop for 50 bucks. I believe it was an older Honda CB. He took it home and tried a rope to it and had a buddy pull it behind his truck. He popped it into gear and it broke free. Without changing the oil he simply added some to it and rode back to the shop and smoked the tire off in their parking lot! This happens to be a guy that rides machines until they die and then leaves them one the side of the rode (so to speak). Like I said, I am not recommending this method but it can work.
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- fandango
30 Jul 2009 17:16 #310434
by fandango
kztee that is good one I keep that as a last chance.
roy I`m trying to get it loose without tearing apart,but I might have to introduce the mallet to him on certain areas.
I did this oil trick before always worked,but not with this.It may be not just frozen.
next step I will try that marvel mystery oil.
Thanks
Thanks
- Beatpoet
01 Aug 2009 11:39 #310754
by Beatpoet
Replied by Beatpoet on topic Frozen KZ 1000 engine
I just broke my kz900 engine loose after about a year of soaking.
A piece of soft wood and a mallet moves it around pretty well now. That's after taking the head off and lightly tapping the piston tops one at a time... A couple of times a day for about a week freed 'em up.
- otakar
01 Aug 2009 11:51 #310755
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Frozen KZ 1000 engine
Pore about one oz of Marvel Mystery oil into each spark plug hole and let it sit for a few days. Put a wrench on the crank shaft and try to wiggle it back and forth until it pops. I would be very careful about banging on top of the pistons. You might misalign the crank shaft. If you do it, use a rubber mallet and tap it gently.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Locozuna
01 Aug 2009 12:28 #310758
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Frozen KZ 1000 engine
Only engine I ever "helped" free up we used Marvel Mystery Oil and let it sit a couple days. Still had to tear it down but the MMO really worked.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- bountyhunter
- Thank you received: 337
01 Aug 2009 13:39 - 01 Aug 2009 13:41 #310767
by bountyhunter
Replied by bountyhunter on topic Frozen KZ 1000 engine
Another good rust penetrator is Kroil.
One place to put a wrench and get some real serious pull is on the flywheel nut. That's a big ass nut that takes over 100 ft-lbs to torque down so you could put a wrench on it and tap the end with a hammer or just hop on it with your foot. It's a left hand thread on mine.
That 17mm nut on the end of the crankshaft by the points is not intended to take a lot of torque. The one on the flywheel sure is.
Last edit: 01 Aug 2009 13:41 by bountyhunter.
