Gasket sealant on both sides of gskt, can't split.
- Sweet Back
- Thank you received: 2098
It appears a brilliant one put gasket sealant on both sides of a gasket and now I cannot seperate the valve head from the jugs. The jugs are lifting but do not want to come up all the way. Can't really pry at it. Tried some gasket remover but that is not going to get in between the metal. Any suggestions would be welcome.
Starting at the top ---
Valve cover
Gasket
Head
Gasket
Cylinders (jugs)
Base gasket
Case
Which gasket?
Good Luck!
- Sweet Back
Valve cover
Gasket
Head
Gasket<<<<<<<<<<<<<<<<<<<<<<<<< This one
Cylinders (jugs)
Base gasket
Case
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- bountyhunter
- Thank you received: 337
You could also soak the sucker in kerosene if it comes to that.
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- Sweet Back
I always get concerned about using force with this stuff.
Putty knife did the trick. Thanks all.
