Strange Vacuum Reading
- Johnj
I have found engines with the correct shims but in the wrong buckets before.
Veho vivo - Ago ut veho
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
- bountyhunter
- Thank you received: 337
Depends: if you can spin the bucket with your fingers, you have some clearance. Assume it's zero and adjust from there and you will be within a thou or so.I appreciate the response, but the problem is that my shims have no clearance to measure! That said, tables and charts will not help me.
BTW, I found a set of feelers that go all the way down to .001" on line.
If it is stuck tight, you need to install a thinner shim and remeasure.
bigkaw815 wrote:
I don't think so.I wonder if I can take out the shims, install the buckets and cams, then measure the distance subtracting proper cam clearance?
- bountyhunter
I recommend making a drawing and writing down which size shims were where when you started.
Proceed to check all the valves, then pull the shims out and use a mike or vernier caliper to measure the thickness (convert to millimeter); then apply the shim size and valve clearance to get proper shim from the chart.
As stated, measure the shims yourself. Then, I label them with a Sharpie to make life easier while I swap them around.
- fixer5000
massachusetts
- bigkaw815
- Thank you received: 1
- Old Man Rock
- Thank you received: 225
Question:
Not to insult, just insuring for one method will make a change in your clearance measurements...
When your rotating the cam lobe for measurements, what's the orientation of the lobe... 45 (side) or 90 degrees (heal) straight up?
Not sure about 650's but if measuring from the non heal, cam lobes are curved and can give you inaccurate measurements...
As mentioned, with the lobe orientation correct if you can spin the shim then you have some sort of clearance...
Ok, Pencil, paper, and caliper..... open her up and measure & record each shim thickness with your caliper. Insert them back to there location after measuring.
They are normally marked with their values, usually inserted with the marking side down so the lobe doesn't wear this data off... Doesn't matter though for you're going to measure them anyways.
From those values, subtract .5 to 1mm. or what ever the spec is for KZ650's...
Something I have been learning...
On the intakes be closure to the low spec on the intakes. For the exhaust, stay closer to the high end of the spec.
Reasoning, the exhaust get's the most heat and the clearances seem to fluctuate more than the intakes...
In either case, just get them into spec....
You can obtain shims @ Z1
www.z1enterprises.com/SearchResult.aspx?All=True&KeyWords=shim
Good luck, let us know how it turns out...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2829
- kz1000dragster
- gane
[img][/img] 1977 KZ1000A1
