- Thank you received: 92
Need a part, HELP!!! Oil Pan Plug for 650...
- Tyler
12 Jul 2009 19:06 #306579
by Tyler
"74 Yamaha DT 400 Enduro
Need a part, HELP!!! Oil Pan Plug for 650... was created by Tyler
I just got the rebuilt engine back in my 1980 KZ 650 and I have a probelm. Originaly the previous owner had an oil cooler on this motor and I am not running one. I need the M17 x 1.25 allen head set screw that plugs the rear of the oil pan. Any of you with an oil cooler know what I am talking about. This is an impossible part to buy as nothing I have found suggests that M17 by 1.25 is even made for anything and my lathe can't cut metric threads. If anyone has this plug or even a whole oil pan with one let me know. My other option is to swap oil pans with and older engine but I don't want to go through that if I can avoid it. Prior to 1980 kawasaki used a M18 hex head plug, after that is was changed to a M17 plug.
- bountyhunter
- Thank you received: 337
12 Jul 2009 19:40 #306605
by bountyhunter
Replied by bountyhunter on topic Need a part, HELP!!! Oil Pan Plug for 650...
I'm not sure what M17 X 1.25 is. I would probably just drill the hole out and tap it to the next size up that I had and then put a bolt in it with red loctite and it will be plugged forever.
- Thank you received: 2829
12 Jul 2009 20:26 #306633
by 650ed
Replied by 650ed on topic Need a part, HELP!!! Oil Pan Plug for 650...
I looked at the Kawasaki.com parts diagrams for the 1980 KZ650-F1 and E1, but I didn't see a plug at the rear of the pan. I do see one on the 1979 KZ650C3 and earlier KZ650 oil pans. Are you sure this hole wasn't drilled by the previous owner? If not, do you have a part number or diagram that shows the plug? Ed
- Tyler
12 Jul 2009 21:25 #306651
by Tyler
Replied by Tyler on topic Need a part, HELP!!! Oil Pan Plug for 650...
Nope its the factory plug that is removed from the rear of the pan when adding an oil cooler. It is not available from Kawasaki. I doubt anyone would "make" that thread as a 1.25 pitch 17mm metric tap is VERY uncommon.
What I can do is cut the barb off of the Lockheart fitting and drill and tap it for a pipe plug. That way I don't have to pull the pan down again.
Just confounds me that Kaw would use such an odd ball thread and diameter, all previous models used a 18mm fine thread bolt, why they changed is beyond me...
- Mark Wing
- Thank you received: 22
13 Jul 2009 00:01 #306677
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Need a part, HELP!!! Oil Pan Plug for 650...
I've got one, PM me your address and I'll send it to you.
Mark
Mark
Yorba Linda Cal.
- Tyler
13 Jul 2009 10:08 #306709
by Tyler
Awesome, thanks man!!!
- Bluemeanie
- Thank you received: 14
14 Jul 2009 20:06 #307102
by Bluemeanie
Replied by Bluemeanie on topic Need a part, HELP!!! Oil Pan Plug for 650...
Mark Wing wrote:
Of course you do, Mark! :woohoo:
Mark
