- Thank you received: 76
KZ Turbo Design Help, Experience A Plus
- saxjonz
- KawboyZ
79 LTD B3
- MrExtreme
saxjonz wrote:
If you want a daily driver then the zrx setup with the mods is the way. You can build your motor and forget it's aircooled and then it won't be a daily driver. I have overheating issues now with my 1075 NA I can only imagine what an 1198 would do when spanked on a hot summer day let alone boosted. I would stay smaller if you are going to boost it to Shiloh and back. But I don't know much about these things just that when you hit it hard and then have to stop at a stop light they aren't very streetable.
You don't quit riding because you got old.
You get old because you quit riding.
- zippy
my biggest issue with the superchargers is its very hard to change your boost without a lot of work changing drive pulleys around,they look cool though
Ouch - You are killin me here Plummen
- PLUMMEN
- Thank you received: 104
when the boost is turned down its basically a 8:1 motor with small cams,very streetable.it will start with an electric start,run on pump gas......... only time boost is a factor under normal conditions is when your laying into itIf you want a daily driver then the zrx setup with the mods is the way. You can build your motor and forget it's aircooled and then it won't be a daily driver. I have overheating issues now with my 1075 NA I can only imagine what an 1198 would do when spanked on a hot summer day let alone boosted. I would stay smaller if you are going to boost it to Shiloh and back. But I don't know much about these things just that when you hit it hard and then have to stop at a stop light they aren't very streetable.
- PLUMMEN
did you notice i said theyre really cool looking? :woohoo: how do you adjust your over/underdrive on the blower without changing pulleys?ive dealt with it on boats before,just more time consuming is allPLUMMEN wrote:
- zippy
Yeah - Have to pull a gear off the blower and reset the idler pully. Takes about 5 min. which was never any big deal. Have gears for both 8 and 20lbs boost setup.
Having built a few dozen turbo bikes over the years as well as a few street supercharged bikes I would say to the OP to consider a few things.
1. Building a turbo bike is gonna be way easier than a supercharged bike. Just way more "kits" out there as well as parts both new and used as well as folks with 1st hand experiance with turbo bikes.
2. As OP stated - if he goes supercharger he is gonna have to do some fabrication work most likely as I don't believe there are any supercharger "kits" out there.
3. As far as positive things about building a supercharged bike - as you mentioned - I just think they look meaner. Everybody and their kid sister has a turbo bike. Not too many folks around with blown street KZs anymore especially if they are injected.
4. Supercharged bikes sounder meaner. No question about it. There is nothing worse in my mind than a 200+ bhp turbo bike that sounds like a motor scooter With a blower bike you can put a header or drag pipes on and maintain that wonderful sound that we all love not to mention the whine of the blower. That just can't be beat in my book.
5. Gotta love that low RPM grunt with a supercharged bike as they are always on boost.
6. As far as performance differences - I figure it really doesn't matter as both systems can produce waaaaaaay more power than the bike or rider can probably handle unless he does some serious frame mods and puts mega bucks into the rear end.
7. I would definately go with EFI on either setup and would be on the phone to Hahn Racecraft in a heartbeat.
8. If it were my bike - and somebody handed me a pile of money to build it - I would luuuuuuuuv to build up a KZ with the new Magnuson Gen. 4 blower and a Hahn EFI injector system. God that would be a gorgeous setup. A real head turner
Just some idle thoughts - drool
Zippy
- MrExtreme
A lot!!!
Thanks, a couple good points to consider, this being my winter project, forced induction of some sort, I have time to research and ask questions.
Are there any carbs that can be used in a blow through application??
Check out this thread, I think I have the back half covered, just have to finish the front.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=305560
- Tyler
- Thank you received: 92
The KZ gods will be pleased
"74 Yamaha DT 400 Enduro
- MrExtreme
Holy #%^@$ if your gonna put a blown, injected engine in that project.... SICK!!!:evil:
Thanks man, yes that is the plan, I have done several Z1/KZ/GPZ bikes in the past, but I have never built a bike to this level, lot's of go, lot's of chrome, lot's of sparkle, it should be a looker!!
- PLUMMEN
- MrExtreme
try a turbo with a bottle and fuel injection,just need some motivation! :laugh:
You forgot intercooled!!!
- PLUMMEN
