1980 kz1000 cam cover gasket issues
- terry s
07 Jul 2009 18:34 #305175
by terry s
1980 kz1000 cam cover gasket issues was created by terry s
What kind of gasket sealer do you use on those half moon cam rubbers to seal them. I used yamabond 4 and they seem to be sliding out. Should I flip them around reverse. They were new and I just put sealer on one surface.
- bountyhunter
- Thank you received: 337
07 Jul 2009 19:08 #305190
by bountyhunter
Replied by bountyhunter on topic 1980 kz1000 cam cover gasket issues
Three bond is good, but you need to get the aluminum dead clean with acetone. Scrape all the old stuff off first. Try this to get the plugs installed right:
Apply a film of 3-bond to the curved side of the rubbers and to the aluminum area they mate with. To get the rubbers set up in the right place, I set the cover on (no gasket) and lightly tighten down some of the screws until the tops of the rubbers are level across the top edge of the head. Let it dry overnight and the rubbers should be installed very solidly in the right place. You can then install the gasket and close it up.
If you install the gasket and rubbers at the same time, the gasket will force the plugs too far down because the gasket compresses between the aluminum areas but stays full width above the plugs and pushes them farther down. You don't want that.
- BARNEYHYPHEN
- Thank you received: 1
07 Jul 2009 19:08 #305192
by BARNEYHYPHEN
Replied by BARNEYHYPHEN on topic 1980 kz1000 cam cover gasket issues
I used the grey colour versa? silicon high temp gasket/sealer. Comes in a tube from Autozone. No leaks. Put plenty on and just make sure the plugs don't push out as you torque down the cam cover.
BH
BH
- bountyhunter
07 Jul 2009 22:11 - 07 Jul 2009 22:15 #305272
by bountyhunter
I use the Ulra HI-temp black gasket maker from auto zone as well. Three bond is a lot stronger and I think a better choice for something you don't plan to take out anytime soon like the rubber plugs, not for gaskets. I use the black stuff for gasket sealing because it scrapes off easily if I have to remove the cam cover.
That's what mine did: when I put the sealer on the plugs and tried to install the gasket and cover (and torque it down) while it was wet the plugs came out. The next time I applied sealer only under the plugs and used the cover to push the plugs down level and let them dry overnight. Then I installed the gasket and torqued it down and the plugs stayed put.BARNEYHYPHEN wrote:
BH
Last edit: 07 Jul 2009 22:15 by bountyhunter.
- APE Jay
- Banned
- Thank you received: 58
08 Jul 2009 09:17 #305402
by APE Jay
Replied by APE Jay on topic 1980 kz1000 cam cover gasket issues
- TeK9iNe
- What did you do!?!
- Thank you received: 28
08 Jul 2009 09:26 #305408
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 1980 kz1000 cam cover gasket issues
Dont bother with the sealer stuff, it goes everywhere.
Just clean up the metal surfaces really good with acetone. Then wrap the plugs 8 times with folded over teflon tape, so that they are bulging up about 2mm above the surface when you install them. When you clamp down the cover, you'll have no leaks for good.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- timebomb33
- Thank you received: 10
08 Jul 2009 10:37 #305431
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1980 kz1000 cam cover gasket issues
do like jay say's and get rid of the problem forever or put the the plugs in backwards so they can't push out try not using any sealer if possible as it can cause them to spit out.
- terry s
08 Jul 2009 18:04 #305517
by terry s
Replied by terry s on topic 1980 kz1000 cam cover gasket issues
I got them to hold this time. I used yamabond 4 and put cover back on without gasket and snugged it down overnight. thanks for all the help guys!!!
- Old Man Rock
- Thank you received: 225
08 Jul 2009 19:21 #305537
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1980 kz1000 cam cover gasket issues
I used the bond case sealer under my end caps and they are aluminum....
In speaking with others who also have aluminum end caps, a little sealer was required in their heads as well....
You don't have to goop it on, just a thin coat...
Then lay your valve cover on top insuring they are parallel with your head... Let the sealer dry then tighten the cover down..
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
