- Thank you received: 1
Valve Adjustment KZ550-C2
- ChicagoLTD
07 Jul 2009 09:01 - 07 Jul 2009 09:02 #305029
by ChicagoLTD
1981 KZ550-LTD (bobber)
Valve Adjustment KZ550-C2 was created by ChicagoLTD
Hello
My kz550 ltd really needs a valve adjustment badly, provided that i have all the needed tools ( feeler gauges,shim tool,etc) is this something that I could do myself?
Im moderately mechanically inclined and have space to do all of this, I just dont want to get in too far over my head.
Last edit: 07 Jul 2009 09:02 by ChicagoLTD.
- harm
- Tom
- Thank you received: 13
07 Jul 2009 09:23 #305033
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic Valve Adjustment KZ550-C2
You should be able to do this. You will need a manual if you don't already have one, Preferably a Kawasaki factory manual. Make sure your local dealer has the shims in stock or that they can get them for you. Other than that it just a matter of taking your time, counting teeth and double checking your work!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- RonKZ650
- Thank you received: 240
07 Jul 2009 09:47 #305040
by RonKZ650
Replied by RonKZ650 on topic Valve Adjustment KZ550-C2
A KZ550 needs the camshafts removed to replace valve shims. It's not hard to do, but you must do it correctly or damage will result.
- Thank you received: 2829
07 Jul 2009 10:12 #305046
by 650ed
Replied by 650ed on topic Valve Adjustment KZ550-C2
Have you already measured the valve clearances?
- bountyhunter
- Thank you received: 337
07 Jul 2009 13:58 - 07 Jul 2009 13:59 #305113
by bountyhunter
Replied by bountyhunter on topic Valve Adjustment KZ550-C2
Make sure you have a low range torque wrench for the cam cap bolts. They strip easily, you only want to put about 80 - 90 inch-pounds on them. You can get a decent 200 I-P wrench at Harbor Freight.
factory service manual is an absolute must. Use Clymers to sop up spilled oil, you need a real manual.
Last edit: 07 Jul 2009 13:59 by bountyhunter.
- ClassicNoob550
12 Jul 2009 12:32 #306493
by ClassicNoob550
'82 KZ550 LTD
Replied by ClassicNoob550 on topic Valve Adjustment KZ550-C2
'82 KZ550 LTD
- 1100sportrider
12 Jul 2009 19:22 #306595
by 1100sportrider
Replied by 1100sportrider on topic Valve Adjustment KZ550-C2
do hi lift cams need extra clearence
- PLUMMEN
- Thank you received: 104
12 Jul 2009 19:42 #306606
by PLUMMEN
Replied by PLUMMEN on topic Valve Adjustment KZ550-C2
how big are they and how hard is it ridden?
