TRICK FOR REMOVING CLUTCH HUB NUT!!! ????
- szczupd
- !!!NEVER BACK DOWN!!!
Re: TRICK FOR REMOVING CLUTCH HUB NUT!!! ????
26 Jun 2009 18:18
you know that makes perfect sense i think I might do that and thanks for the link now I know how to attack this
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
1982 KZ750H LTD
- thompsonmx100
26 Jun 2009 20:48
for a cheap clutch holding tool you can use a tiedown strap. The end without the ratchet or buckle. You use the hook end and attach it to the frame. Then use the other end wrap it around the clutch hub in a way that as you loosen the nut you tighten the strap or counter clockwise around the clutch basket. Then use a set of vise grips to hold the strap to the basket. Then the basket will be held in position then get a long 1/2 inch ratchet and give it a good solid jolt.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- N0NB
- Blue handles better
27 Jun 2009 05:51
My neighbor has a clutch holding tool made from four clutch plates tack welded together sid by sid with a piece of squre tubing across them offset from center so the nut can be accessed. A bar goes into the tubing to hold the basket. I liked it so much he had one made for me.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- Old Man Rock
27 Jun 2009 08:18 - 27 Jun 2009 08:19
Maybe this will help... Excerpt out of my KZ900 Shop Manual...
"four clutch plates tack welded together"... Yup!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 27 Jun 2009 08:19 by Old Man Rock.
- szczupd
29 Jun 2009 09:58
thanks for the ideas guys orderd the tool today well see how it turns out when it comes in and another buddy of mine that rides said 99 percent of the time you need to you use an impact gun on these things wrench is worthless
1982 KZ750H LTD
1982 KZ750H LTD
- franknsr
29 Jun 2009 19:12 - 29 Jun 2009 19:13
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Last edit: 29 Jun 2009 19:13 by franknsr.
- larrycavan
29 Jun 2009 19:21
What are you doing that requires you to remove the clutch hub?
- trianglelaguna
29 Jun 2009 19:37
that is timeless......
larrycavan wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- irishwill
29 Jun 2009 19:50
pull out plug in #1 make sure the piston is on its way up on the compression stroke....now fish a piece of soft 1/4 " nylon cord (rope ) into the cylinder....enough so the piston cant pass tdc...I would only do this if I was stuck...but I have done it and it has worked
- szczupd
30 Jun 2009 09:04
I have to remove the secondary shaft to replace the starter clutch and the only way to get to the shaft is by removing the clutch hub to remove the retaining plate its a pain in the a#$ but I want my bike to start lol
1982 KZ750H LTD
1982 KZ750H LTD
- Barber
02 Jul 2009 05:22
szczupd wrote:
And then you'll want to ride it.. Some people are just never satisfied... :dry:
Green 76 Z900 A4
