TRICK FOR REMOVING CLUTCH HUB NUT!!! ????
  • szczupd
  • szczupd's Avatar Topic Author
  • !!!NEVER BACK DOWN!!!
26 Jun 2009 12:17
#302252
Hey guys can anyone tell me a trick for removing the clutch hub nut. Ive tried like crazy to get this thing off but im afraid of rounding out the nut I ahve on order the clutch hub pliers to hold the hub but I dont know man seems shady as my previous idea was to shady for me to actually go through with
Any Advice?
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
  • anarki650
  • anarki650's Avatar
Re: TRICK FOR REMOVING CLUTCH HUB NUT!!! ????
26 Jun 2009 12:24
#302254
Two words: air impact
Or you can beat yourself crazy for hours at a time trying to get the damn thing to bugger off. The choice is yours my friend...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • szczupd
26 Jun 2009 12:26
#302255
LOL thought of it and was great idea till I realized I dont have an impact gun LOL LOL I am trying to avoid that but if not I'll see if I can rent one from Home Depot or something
1982 KZ750H LTD
  • anarki650
26 Jun 2009 13:06
#302271
Throw your bike in a truck and take it to a small shop somewhere close, bring a dozen donuts and offer them up as payment for the guy willing to take 2 seconds to spin the nut off for you. Should be done in about 3.5 seconds...
09 Kawasaki ER6n
Omaha NE
  • szczupd
26 Jun 2009 13:14
#302272
LMAO!!!! You know I'm upset I cant get this thing off but your reply has put the biggest smile on my face LOL Oh and just one dozen or two it might take a whole 5 seconds LOL
1982 KZ750H LTD
  • bountyhunter
  • bountyhunter's Avatar
26 Jun 2009 14:14
#302284
have you tried putting a big box end wrench on it and tapping the wrench handle with a hammer?
The other thing is one of those strap wrenches everybody sells for gripping clutches.
  • szczupd
26 Jun 2009 15:57
#302307
Im afraid to tap on a wrench like that, i was always told to apply steady pressure in a situatuion like this and the elastic grip wrench thing I tried already, nuts to thats idea she just spins:unsure:
1982 KZ750H LTD
  • PLUMMEN
  • PLUMMEN's Avatar
26 Jun 2009 16:00
#302308
breaker bar with 10' cheater pipe while somebody holds the brakes for ya :laugh:
  • Barber
  • Barber's Avatar
26 Jun 2009 16:46 - 26 Jun 2009 16:47
#302320
just put the right sized wrench on it and smack the hell out of the other end with a hammer.... it "shocks" it loose.. same basic principle as an impact gun....
Green 76 Z900 A4
Last edit: 26 Jun 2009 16:47 by Barber.
  • bountyhunter
26 Jun 2009 17:15 - 26 Jun 2009 17:16
#302322
+1 A steady pressure twist is actually what can shear things off, the sharp jolt is what makes things break loose.
Dumb question: did you try spraying the hell out of the nut with penetrating oil spray?
The other tool which might work is a hand drive impact driver. They are cheap (I think I have thee of them) and they have a 1/2 drive head on them you can put a socket on. You smack them on the end with a hammer and they twist the head. Only worry is it may not be a good idea to be smacking inward on the end of the crankshaft (?)
Here's an example:
www.tooltopia.com/index.asp?PageAction=V...m_campaign=nextag_r1
Last edit: 26 Jun 2009 17:16 by bountyhunter.
  • bountyhunter
26 Jun 2009 17:19
#302324
I seem to remember way back when I changed my clutch having my left foot on the rear brake pedal while I beat on the wrench....:laugh:
I suppose that means I had it in gear?
  • fochtup1
  • fochtup1's Avatar
26 Jun 2009 17:36
#302329
i use a penny in between the gears...wont hurt the gears as copper is a softer metal.
