TRICK FOR REMOVING CLUTCH HUB NUT!!! ????
- szczupd
- !!!NEVER BACK DOWN!!!
Any Advice?
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
- anarki650
- Thank you received: 5
Or you can beat yourself crazy for hours at a time trying to get the damn thing to bugger off. The choice is yours my friend...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- szczupd
1982 KZ750H LTD
- anarki650
09 Kawasaki ER6n
Omaha NE
- szczupd
1982 KZ750H LTD
- bountyhunter
- Thank you received: 337
LMAO!!!! You know I'm upset I cant get this thing off but your reply has put the biggest smile on my face LOL Oh and just one dozen or two it might take a whole 5 seconds LOL
have you tried putting a big box end wrench on it and tapping the wrench handle with a hammer?
The other thing is one of those strap wrenches everybody sells for gripping clutches.
- szczupd
1982 KZ750H LTD
- PLUMMEN
- Thank you received: 104
- Barber
Green 76 Z900 A4
- bountyhunter
+1 A steady pressure twist is actually what can shear things off, the sharp jolt is what makes things break loose.just put the right sized wrench on it and smack the hell out of the other end with a hammer.... it "shocks" it loose.. same basic principle as an impact gun....
Dumb question: did you try spraying the hell out of the nut with penetrating oil spray?
The other tool which might work is a hand drive impact driver. They are cheap (I think I have thee of them) and they have a 1/2 drive head on them you can put a socket on. You smack them on the end with a hammer and they twist the head. Only worry is it may not be a good idea to be smacking inward on the end of the crankshaft (?)
Here's an example:
www.tooltopia.com/index.asp?PageAction=V...m_campaign=nextag_r1
- bountyhunter
breaker bar with 10' cheater pipe while somebody holds the brakes for ya :laugh:
I seem to remember way back when I changed my clutch having my left foot on the rear brake pedal while I beat on the wrench....:laugh:
I suppose that means I had it in gear?
- fochtup1
