- Thank you received: 5
750 4 cam timing
- jordan
Right know, with the cylinders 1 and 4 at tdc, z7ex is level with the head on the exhaust camshaft, and in is level with the head on the intake camshaft. They are spaced the right number of teeth apart(45-46). But the exhaust cam sprocket is bolted on with the square mounting hole, and the intake cam sprocket is mounted with the circle mounting holes. Does anybody know if this is wrong and what is the correct way????
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- agawam
- jordan
I have never seen anything like this. Its probably just something stupid that i am missing but i dunno. I threw a head gasket for the stock 750 motor on my 810 to get it running like said above. Now i just put on my wiseco 810cc head gasket to correctly fit, and i tightened down the head pretty good with the ratchet, but have not yet torqued it. The cams are not in, just the head bolted down. I am still getting only about 30 pound of pressure in each cylinder! What might be my problem!!! It has not been running for a while know, and all i want is to ride again.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
ANY IDEAS????
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Thank you received: 2098
Thought i found the compression problem, but was once again let down. I rememvered that i did not have any of the stock washers under the head nuts, and thought maybe the nuts were bottoming out. So i used my deep APE head nuts, and tightened those on there. Still only getting a little over 30 pounds of pressure.
ANY IDEAS????
Leakdown test should determine source of compression loss.
Good Luck!
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Of course not up to standards of a real leakdown test tool , but fast and cheap!
Good Luck!
I will try a leakdown test. Can the tools to do a leakdown test be bought at most autoparts stores? The wierd thing is that this head was just removed from a perfectly running motorcycle. My buddy just replaced it with a GPZ head
Can the tools to do a leakdown test be bought at most autoparts stores? -- Yes, and also at Z1E.
Good Luck!
