- Thank you received: 1
750 4 cam timing
- agawam
05 Jul 2009 06:40 #304512
by agawam
Replied by agawam on topic 750 4 cam timing
whatever you do don't check the valve clearence,its not that important that the valves be closed to run properly,
- Old Man Rock
- Thank you received: 225
05 Jul 2009 07:14 #304516
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 750 4 cam timing
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- jordan
- Thank you received: 5
05 Jul 2009 12:17 - 05 Jul 2009 12:18 #304582
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic 750 4 cam timing
agawam wrote:
Since i don't have the camshafts in, all the valves are closed. Still coming up with poor compression. Will have to order a leak down tester, so i guess i will have more time to wait. To me it is just odd that this head came off a running bike with good compression about 2 months ago, and now i throw it on my bike and i am checking to see if i am losing compression through the valves? It shouldnt be. Also, i cant see the problem being rings, as i had good compression before i pulled the gpz head. I guess we will see where i am losing compression when i get my hands on a leak-down tester.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Last edit: 05 Jul 2009 12:18 by jordan.
- Jonus079
08 Jul 2009 14:05 #305483
by Jonus079
Replied by Jonus079 on topic 750 4 cam timing
You cant do a compression test with the cams out. it needs to suck air in and compress it. This is the same reason people say do a compression test with the throttle wide open.
- jordan
08 Jul 2009 21:13 #305553
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
thank you for that answer. My buddy just mentioned that to me tonight, and now i feel like a retard for not realizing it. I am busy for a couple days, but will hit it pretty hard again asap and be back on the road soon.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
09 Jul 2009 22:06 #305811
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
cams in, timed, everything reassembled, good compression, good spark, but wont start. By the time i got it put together it was getting pretty late so i just cranked it over to see if it would even try to start. Wires are in the right order. Should be getting fuel, i sprayed starting fluid in the carbs a couple times, and just got a flame out the exhaust. No loud popping, or attempt to start! WTF!!!
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Jonus079
10 Jul 2009 18:48 #306033
by Jonus079
what were the compression #'s?? Try putting you hand over the carb one at a time while cranking. Your hand should get covered in gas when you do this.
- jordan
13 Jul 2009 23:48 #306892
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Bike is running now, but the topend change did not get rid of the knock that i tore it down to fix. Still runs as good as ever, but with an annoying knock. If a circlip came out on one of my pistons, what would happen? Would it cause a knock?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
