- Thank you received: 3
Big bore VS Small bore
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
I think everyones answer was correct! I would of went for spin it faster, but hard with cams and head the same. Maybe a good way to even up, displacement differances.
Larry is there a way to do the math for, lets say, pro stock motors running at the same speed.
1015cc @ 10,500 rpms (peak power)
1200cc @ 10,500 rpms (peak power)
Larry was the 113% Ve, ever possible?
- larrycavan
- Visitor
Damn good job everybody!
All i/c motors....To increase power output....
1. make it bigger
2. spin it faster
3. make it more efficient
Yes, 113% is realistic on a tuned Z.
How big it is, drives the reasoning behind the choices when you want to spin it faster.
- PLUMMEN
- Thank you received: 104
- PLUMMEN
- davel
90% spent between 3000 - 6000 on the streetid say closer to 6000
- PLUMMEN
exactly so build accordingly.38 flatslides and 435 cams with large by huge intake ports are cool on a dragbike with throttle pinned for 9 seconds but are of very little use on a streetbikePLUMMEN wrote:
- larrycavan
- Visitor
- kzz1p
Carb and cam it for how you ride it.....or ride it for how it's cammed and carbed...
Now thats a good line!
- irishwill
- Thank you received: 6
i weigh 240#...so bigger is better...I agree with you plummen on the 1197 motor...
- PLUMMEN
- larrycavan
- Visitor
If you look at the OEM engineer's setups, 2 things clearly dominate.
In all cc limited bikes, RPM is climbing all the time.
In bikes where cc limits are not a concern....they're getting bigger all the time.
Remember the days when guys would debate 340 vs 440 mopars
Both were a joy to own. The question was are you more comfortable in a GTX or a Cuda? :laugh:
- saxjonz
- KawboyZ
- Thank you received: 76
larrycavan wrote:
1200cc KZ motors are good all around setup for everyone. Only drawback is it bites the budget a little harder.
79 LTD B3
