- Thank you received: 3
Big bore VS Small bore
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
So here is my story problem:
Can a small bore engine (example 1015cc) pump as much air, as a big bore engine (example 1200cc), in the same amount of time? If so, then how? If not, then why?
- Thank you received: 2829
- PLUMMEN
- Thank you received: 104
- PLUMMEN
- kzz1p
now if the 1075 was built by Larry C,all bets are off! :laugh:
If the head was built by Byron Hines or Jerry Branch or Rob Muzzy, is the bet on? Haha!
I'm thinking all things equal, except bore size.
- kzz1p
Are we talking about both engines operating at the same RPM? Ed
We are only talking about bore size and time.........
- PLUMMEN
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- kzz1p
In that case, a smaller displacement engine may pump more air than a larger one. Example, let's say a high tech modern engine like a ZX10R is 1000 cc's (actually 998cc)and redlines at 13,000 RPM (no joke). An unscientific measurement says 13,000 RPM X 1000cc = 13 million cc per minute. If I have a 1200 cc KZ that redlines at 10,000 RPM the same equation 10,000 RPM X 1200cc = 12 million cc per minute or 1 million cc per minute less. Of course, if both bikes achieve the same redline the larger displacement machine will suck in the most air. Or, as Thomas Ed points out, if one has a turbo it wins.
2009 ZX10R
- larrycavan
- Visitor
3 motors - 1166cc, 1075cc, 1015 all w/ 10.5:1 compression
Peak HP RPM of 8200 for the 1166
Piston demand at 75* ATDC 140.2 CFM
@113% Ve - Cylinderhead CFM requirements 123.4 - 129.4 CFM
Average Crankshaft HP@600RPM Accel Rate 135.3
Peak HP RPM of 8800 for 1075
@113% Ve - Cylinderhead CFM requirements 123.4 - 129.5 CFM
Average Crankshaft HP@ 600RPM Accel Rate 136.8
Peak HP RPM of 9300 for the 1015 motor
Piston demaind at 75* ATDC 140.2 CFM
@113% Ve - Cylinderhead CFM requirement 123.4 - 129.4 CFM
Average Crankshaft HP @600RPM Accel Rate 137.8
This assumes all are cammed and carbureted properly for their intended peak hp rpm
Making peak horsepower is one thing. Making broad, street friendly power is another.
- trianglelaguna
- Thank you received: 235
thread....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
