- Thank you received: 225
Not Bent Valves! Head Gasket Issue!
- larrycavan
- Visitor
15 Jun 2009 17:04 #299445
by larrycavan
Replied by larrycavan on topic How long can you ride on a bent Valve?
PLUMMEN wrote:
Me too.
I had a kz900 motor a guy brought in one time to have the timing set on. It was in a sand drag car. Timing was off a couple of degrees. I had it on the money in about 1 minutes time.
Guy looks at me and says Ok but listen to this. He grabs the throttle and holds it about 5000RPM. Breaking up and popping something terrible. Let it idle and just lightly rev it and it sounded not too bad.
This thing smoked a bit when you let off on it and thats all! Pretty typical hard run KZ900 motor IMO.
Then I spot the Nitrous fittings but no bottle. I ask the guy about that. He confirmed he had run it on juice for a while. I check compression and one cylinder had 50lbs. The others were about 90 PSI.
Guy takes it home and tears it down. I stop that night on my way home to see how he made out.
GET THIS - When he took the block off, most of the ring lands for the top rings on all 4 pistons fell off in little pieces :huh:
True story..swear to God..
Nitrous blew the ring lands to pieces but nothing could go anywhere so it kept running. :laugh:
ive seen plenty of motors with cooked valves and bad rings that ran,some of them ran suprisingly well! :laugh:
Me too.
- Old Man Rock
15 Jun 2009 17:43 #299450
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How long can you ride on a bent Valve?
Broken rings.... Ahhhhhhh, reminder as kids growing up on 2 stroke dirt bikes.... :laugh: :laugh:
Frigging thing would be rattling and pinging all over the place... not to mention smoking like a bitch but ride on.... Get me home old girl... :laugh:
Ah, miss the days.... :blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- dearthchris
15 Jun 2009 17:59 #299460
by dearthchris
Replied by dearthchris on topic How long can you ride on a bent Valve?
HEY GUYS IT TURNS OUT THE VALVES ARE NOT BENT...... MISS-COMMUNICATION!
It does however have a "blown" head gasket. Which I kind of had a feeling was a problem anyways because there is a tiny bit of oil around where the head meets. So the guy "adjusted" the valves, and "freed" up the "advancement".
The bike runs much better it doesn't have the sputter and hesitation that it had before. The problem is though it heats up way too hot and way too fast.
How much would it realistically cost me to replace the head gasket? Should this in theory eliminate my over heating problem?
Thanks Again Guys!
Thanks Again Guys!
- Thank you received: 797
17 Jun 2009 09:36 #299892
by 531blackbanshee
Replied by 531blackbanshee on topic How long can you ride on a bent Valve?
not sure on the price of parts for your bike.
yes the head gasket being blown can(will) cause overheating.
leon holmes
leon holmes
- timebomb33
- Thank you received: 10
17 Jun 2009 10:21 #299906
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic How long can you ride on a bent Valve?
your probably looking at a couple hours labor if that is the only thing you need to get it going again.
- Thank you received: 2098
17 Jun 2009 11:45 #299916
by Patton
Replied by Patton on topic How long can you ride on a bent Valve?
If not already done, would perform compression test to help confirm diagnosis of blown head gasket, and a leak down test also if feasible.
Would also assure correct ignition timing by using a strobe type timing light. And also watching advancer move back and forth with rpm changes when blipping the throttle.
Would remove spark plug and examine color at business end (plug reading).
Over heating can result from several different reasons besides blown head gasket, such as issue with carb, fuel mixture, floatbowl fuel level, oil quality, oil level, oil pressure, incorrect spark plug, excessive rolling drag (brake, wheel bearings, drive chain, insufficient tire air pressure), air filter, clutch slipping, air leak, etc.
What appears to be oil seepage between head and jug might upon closer examination be traceable instead to leakage of valve cover gasket, tach drive, exhaust gasket, etc.
And the head nuts might simply need to be torqued to specs.
Good Luck!
Good Luck!
- Old Man Rock
17 Jun 2009 13:39 #299934
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Replied by Old Man Rock on topic Not Bent Valves! Head Gasket Issue!
To add what Patton was hitting on...
freed" up the "advancement. The problem is though it heats up way too hot and way too fast."
When freed did he re-set the timing?
Resoning I ask, if your timing is advanced even a couple of degrees it will run hotter as well...
Just a thought... Now I'll shut my pie hole....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
