Not Bent Valves! Head Gasket Issue!
12 Jun 2009 15:34 - 15 Jun 2009 18:00 #298642 by dearthchris
Not Bent Valves! Head Gasket Issue! was created by dearthchris
So my 1980 KZ250 that was giving me problems, is in the hands of a mechanic. He has told me that the bike has a bent valve. He said that he can get the bike running good, but not to hang on to it for long. How long can you run on a bent valve in a 1 cyl. motor?
Thanks
Last edit: 15 Jun 2009 18:00 by dearthchris.
12 Jun 2009 16:08 - 12 Jun 2009 16:11 #298646 by Russ Jackson
Replied by Russ Jackson on topic How long can you ride on a bent Valve?
Not long. A week, a day, an hour. The better question is why would you ride it at all?.
Is the Mechanic suggesting you get it running and sell it to someone before it breaks?.
Fix it first or tell the new buyer what is wrong with it...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Last edit: 12 Jun 2009 16:11 by Russ Jackson.
  • Kawickrice
12 Jun 2009 16:10 #298647 by Kawickrice
Replied by Kawickrice on topic How long can you ride on a bent Valve?
When the motor turns to shrapnel it to late. If you know its bent don't ride it unless you need a shiney boat anchor.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
12 Jun 2009 19:18 #298719 by 650ed
Replied by 650ed on topic How long can you ride on a bent Valve?
First I would ask how does he know it's a bent valve? Did he pull the head and see this condition? If so, what caused it to be bent? Valves don't simply bend unless they come into contact with something hard (like a piston or another valve). Anyway, if he pulled the head he should be able to determine what bent it (whatever it was may also be damaged), and if he pulled the head why not simply fix it while it's apart? Did he say how he was going to get the bike "running good" with a bent valve? I'm no professional mechanic, but this doesn't seem possible to me as the bent valve isn't likely to seat well enough to seal the head for compression. You may want to get a second opinion. Ed
12 Jun 2009 19:36 #298722 by timebomb33
Replied by timebomb33 on topic How long can you ride on a bent Valve?
if a single cylinder engine has a bent valve it won't run as the engine will not have any cylinder pressure cylinder, pressure will escape thru the valve seat of the bent valve please find out how this genious has come to the conclusion that the valve is bent.
I THINK MY POWERBAND BROKE
12 Jun 2009 21:17 #298739 by bountyhunter
Replied by bountyhunter on topic How long can you ride on a bent Valve?
That's what it sounded like to me......:huh:
12 Jun 2009 22:51 - 12 Jun 2009 22:53 #298750 by Mcdroid
Replied by Mcdroid on topic How long can you ride on a bent Valve?
As the others said...those two statements are not compatible...the bike can't run good w/bent valve...it can't even run...change mechanics. :blink:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 12 Jun 2009 22:53 by Mcdroid.
13 Jun 2009 04:54 #298764 by dearthchris
Replied by dearthchris on topic How long can you ride on a bent Valve?
Thanks guys. Yeah he basically said get the bike running and sell it right away. I am not a mechanic by any means but I didn't think a motor would even run / idle if a valve is bent? How many valves would my bike have? Could the timing being wrong bend a valve? He was under the impression that the valve has been like that, and that the previous owner pulled on over me. I paid 650 bucks for it, it's my first bike that I am learning on. I wouldn't want to scam the next person that buys it from me, I truly just want to ride it.
13 Jun 2009 05:36 #298768 by Mcdroid
Your bike only has two valves (inlet and exhaust)...If even one is bent, then the combustion chamber isn't sealed at the correct time and you can't have compression and combustion = no running. Yes, a jumped and or stretched timing chain can cause a bent valve. BUT, if the bike runs, then it can't be a bent valve. I think this mechanic is putting one over on you and just doesn't want to work on the bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
13 Jun 2009 09:14 #298811 by austin3119
Replied by austin3119 on topic How long can you ride on a bent Valve?
Why not just get it fixed and start riding?
13 Jun 2009 18:17 #298918 by PLUMMEN
Replied by PLUMMEN on topic How long can you ride on a bent Valve?
ive seen plenty of motors with cooked valves and bad rings that ran,some of them ran suprisingly well! :laugh:
15 Jun 2009 14:06 #299410 by racer54
Replied by racer54 on topic How long can you ride on a bent Valve?
Had a brother-in-law who was the world's best mechanic (according to him!). Rebuilt a Z1 motor and started it up. Bent every valve in the motor. Had the cams off by a tooth I believe (been years ago). Made noise but ran good considering. Motors will run with a bent valve. Depends on the degree of bend. A motor can run with too tight valve clearances to. It just won't be as good as it could be if everything was right. Best, if wanting to keep it, to just get it fixed and be done with it so you won't worry about it later. Peace of mind is priceless at times.
