- Thank you received: 58
valve cover gasket
- APE Jay
- Banned
- The Garbone
- User is Currently waiting for his bailout check..
30 May 2009 16:28 #295120
by The Garbone
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
Replied by The Garbone on topic valve cover gasket
APE Jay wrote:
Very nice, I will have to remember those for next time I pull my lid...
kzzone.com/plugs.html
1979 KZ650 & Hack
1949 Ford 8n
- gane
- Thank you received: 1
30 May 2009 19:52 #295165
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic valve cover gasket
Not to cause hate & discontent, but. I check clearances annualy, even tho bike seldom see's more than 4k annually., still, by prepping valve cover w/yamaha bond 4 and lightly prepping cyl head w eng/oil, find that valve cover gasket /bits are intact after impact for inspection.even if failed, allows cleaning on bench instead of carving on head,anyone who's spent hours scraping head for valve cover gasket will understand. Also, if your bike is worn and tends to blow out cam end plugs due to crankcase pressure, installing cam end plugs inside out will insure placement until you can fix. yar, I was young and broke too.a G
