header exhaust
  • Darkangel
  • Darkangel's Avatar Topic Author
header exhaust
25 May 2009 20:55
#294060
Does header exhuast really hurt the power on my KZ1100, and if so, why?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • PLUMMEN
  • PLUMMEN's Avatar
Re: header exhaust
25 May 2009 20:59
#294063
im sure there are many headers that work worse than stock exhuast B)
  • Darkangel
Re: header exhaust
25 May 2009 21:05
#294068
lol ok that doesn't help.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: header exhaust
25 May 2009 21:09
#294070
weve had discussions before about dyno results of differant headers robbing power,most ads are hyped up to sell parts B)
  • killerkaw
  • killerkaw's Avatar
Re: header exhaust
25 May 2009 21:12
#294074
most header and pipe setups force you to trade torque for hp and the japs did a decent job of balancing both really just be sure to do your homework and buy the pipes that fit your riding style
  • Darkangel
Re: header exhaust
25 May 2009 21:13
#294075
I love the way my headers alone make my bike look...I want to muffle the sound down a little bit, and wrap them up....I dont have the money to get an exhaust system...
  • PLUMMEN
  • PLUMMEN's Avatar
Re: header exhaust
25 May 2009 21:14
#294077
what kind of header are you running?
  • Darkangel
Re: header exhaust
25 May 2009 21:18
#294084
stock....I cut them from the collector..i have a few pics here on the forum...and you can see how they look...
  • bountyhunter
  • bountyhunter's Avatar
Re: header exhaust
25 May 2009 22:12
#294098
So, you are running a straight pipe. Yes, that will screw up the power your motor makes.
Yeah, straight pipes tend to make your ears hurt.
  • Darkangel
Re: header exhaust
26 May 2009 07:53
#294135
why does it hurt it..?
  • bountyhunter
Re: header exhaust
26 May 2009 15:38
#294181
Bike engines make a LOT of power from very small displacement. To do that, they are tuned up very precisely for airflow and fuel mixture. The intake side (carbs and airbox) along with the exhaust system have airflow characteristics that the carburetors are designed to match. That's why carburetor needles have a specific size, length and taper. Changing the exhaust changes the airflow rate through the engine. Going to a straight pipe greatly reduces backpressure making more air flow through the engine, which means that it will be running too lean with the carbs which were designed to work with the stock exhaust.
Re: header exhaust
26 May 2009 16:18
#294195
Motorcycle exhaust systems are engineered for the specific engines to which they attach. On stock bikes, the factory engineers match the flow characteristics of the exhaust system to that of the engine and carbs to strike a balance between power across the entire powerband and sound attenuation. On race bikes sound attenuation isn’t really an issue so the exhaust is tuned to work at the powerband range most important to the type of racing involved. For example, they may sacrifice power at low RPM to maximize power in the meat of the powerband. Take a look at pictures of any superbikes and you’ll see they don’t simply cut off the pipes. They all have small but highly engineered “mufflers” (by Yoshimura, Muzzys, or some other engineering firm) who purpose is to maximize power rather than minimize sound. Aside from the power loss and excessive noise, open headers can lead to valve failures. Ed
