- Thank you received: 9
Oil pressure
- Bdog
- Sweep the leg johnny!!!
25 May 2009 05:27 #293814
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Oil pressure was created by Bdog
What options are there for a gauge for oil pressure? Like I've seen the ones that screw in the oil fill port, just don't remember if they were for a 650/750 block. any ideas?
Brandon
Brandon
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Mark Wing
- Thank you received: 22
25 May 2009 10:52 #293875
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Oil pressure
The service manager at Whittier Kawasaki told me not to run one on my 650. He said they run such low presure that it would just scare me.
Mark
Mark
Yorba Linda Cal.
- MFolks
- Thank you received: 540
25 May 2009 10:55 #293877
by MFolks
Replied by MFolks on topic Oil pressure
The oil pressure on the older 4's is I believe 2.8 to 3 PSI when the engine is fully warmed. It will take a special low pressure gauge to read it due to roller bearing crankshafts.
- timebomb33
- Thank you received: 10
25 May 2009 12:02 #293891
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Oil pressure
650's and 750's use a plain bearing crank so they use quite a bit higher oil pressures than a 900 or 1000. according to the factory manual the pressure should be between28-36 lbs and the port to check it is located directly underneath the ignition housing.
- bountyhunter
- Thank you received: 337
25 May 2009 14:02 #293918
by bountyhunter
Replied by bountyhunter on topic Oil pressure
I got one a long time ago for my 750. I think I got it from JC Whitney. It has fittings that screw into the hole in the crankcase where the stock sending unit goes. Oil pressure is kind of like the weather: you can measure it and talk about it, but (short of an engine rebuild) there's nothing you can do about it.
