How often to change oil/plugs, etc...
- Ashbane
I found an ap called Gas Cubby that I LOVE for my iPod and I use it extensively, I'd like to put in all the right scheduled maintenance things into it to keep the bike in shape.
What other kind of routine maintenance schedules do people do on their bikes, like the plugs, lubing the chain, etc... Like I said, I have the original manual but it seems pretty outdated and I don't know if it's all obsolete info.
1976 KZ750 B1 Twin
- Thank you received: 2098
1976 KZ 750 twin. Original manual I have shows changing oil every 800 km (500 miles). Is this what everyone else does with their bike? seems kinda overkill...have the original manual but it seems pretty outdated and I don't know if it's all obsolete info.
Am guessing the manual may specify the first oil change at 500 miles (new bike break-in), and thereafter at 2000 mile intervals, with filter change every other oil change. At least that's what the 1973 Z1 and 1976 KZ900 manuals provide, consistent with the KHI FSM's for large four KZ's through 1979 models.
The basic routine maintenance as provided in the manual should imo still apply and be followed.
Good Luck!
- bountyhunter
- Thank you received: 337
That can't be correct, According to my 1979 KZ750-B4 (twin) manual, the FIRST oil change (when new) occurs at 500 miles, but all changes after that are every 3000 miles. Filter is changed on every other oil change. As to whether 3k miles is a good change interval? Depends on the oil and type of service. If it is mostly city driving, I change my oil at about 1500 - 2000 miles. If you use premium syn oil like Amsoil or Rotella, you can run it longer.1976 KZ 750 twin. Original manual I have shows changing oil every 800 km (500 miles). Is this what everyone else does with their bike? seems kinda overkill.
Ashbane wrote:
Clean and lube the chain every 200 miles if you want it to last any time. I switched to Dupont Multi Use spray lube for the chain (get it at Lowes) because it is much cleaner to use.What other kind of routine maintenance schedules do people do on their bikes,
I think you can run spark plugs a long time (at least 10k miles) if the engine is burning clean. I sometimes clean and regap the plugs if they look carboned up, the manual says clean and regap every 3000 miles normal maintenance.
- Ashbane
Wow never looked past the first column on the chart, figured they were all the same period in between...
Thanks all. Especially about the chain lube, was hoping to see if a specific kind would come up here.
1976 KZ750 B1 Twin
- oldcoldankles
The best way to find the answer to that question for your bike, oil type and riding conditions is from used oil analysis, ie Blackstone Labs. I use 10W-40 and have it tested locally by Caterpillar, they are currently recommending 2,200 miles for my bikes. I always change mine before the 100° weather arrives so that it's hot weather viscosity is maximized. Your recommendation might quite likely be different. Recently our local Freightliner dealer installed a Shell testing machine right at the parts counter where you can test your own oil and print out the results in 10 minutes for about $15.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
