Streightening a twisted KZ1000/1100 Crank
17 May 2009 10:16 - 17 May 2009 10:23 #291905 by otakar
Has anyone here ever tried this job? With success? Can you do it cold or do you have to heat the counterweight? I figured that if one piston can do this with about 25foot pounds of torque, than a long pipe should be able to exert more than enough pressure to put it back. No I have not twisted one, but was wondering about the process of realignment. Has anyone ever noticed that the Kawasaki shop manual makes no mention of this inspection or problem AT ALL.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 17 May 2009 10:23 by otakar.
  • z1kzonly
17 May 2009 12:43 #291919 by z1kzonly
Replied by z1kzonly on topic Streightening a twisted KZ1000/1100 Crank
Cold, piece of cold rolled steel, a "Barney Rubble" small handle sledge hammer. In a V block jig.
And BAMM. BAMM. And a lot of patience!
And a piece of 17mm rod that is true and straight.
Did this at Jims Cylinder Heads shop in Buffalo.
Jim re-built cranks all the time.
Jim used to run a Top Fuel Kawi with Elmer and Larry
17 May 2009 13:23 #291924 by PLUMMEN
Replied by PLUMMEN on topic Streightening a twisted KZ1000/1100 Crank
good ol blacksmithing! i like hammering on things as much as anybody,but i think that one is out of my skill patience range! :laugh:
17 May 2009 13:35 - 17 May 2009 13:36 #291929 by harm
Once a crank is twisted and then straightened is it more likely to twist again?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Last edit: 17 May 2009 13:36 by harm.
17 May 2009 13:37 #291931 by PLUMMEN
i would definately weld after straightening B)
17 May 2009 16:22 #291963 by otakar
Replied by otakar on topic Streightening a twisted KZ1000/1100 Crank
I agree with the welding once straightened. I was hoping that I could do it cold. It is quite cheap to find a twisted on for a spare than buying a good on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
17 May 2009 16:28 #291964 by otakar
I looked in my 81-84 book and there is nothing in there at all on crank twisting inspection.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
17 May 2009 23:16 - 17 May 2009 23:21 #292328 by RacerZ
Replied by RacerZ on topic Streightening a twisted KZ1000/1100 Crank
This was from 78-80 Manual, but you get the idea. Also a link.
www.mcmaster.com/#88625k77/=1x84c7
Last edit: 17 May 2009 23:21 by RacerZ.
17 May 2009 23:22 - 17 May 2009 23:26 #292329 by RacerZ
Again
Last edit: 17 May 2009 23:26 by RacerZ.
17 May 2009 23:26 #292330 by RacerZ
Again re-size
18 May 2009 05:18 - 18 May 2009 05:22 #292355 by otakar
AH- the same thing is in mi manual, but notice that nowhere it talks about crank shaft twist on the main bearing journal. This is what we are talking about here. I checked all of my manuals, for the 900 1000 and J and nowhere they even make a mention of it. They make the same measurements in all of them and it only covers ROD twisting and bearing ware. The problem is not even the Con Rod big end journal (which I have seen welded many times)It is the main nearing journal that they slip in and what will cause the problems. Because of the location it is hard to get to with anything els but a rod welder.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 May 2009 05:22 by otakar.
18 May 2009 05:30 #292357 by Jack
Jim used to run a Top Fuel Kawi with Elmer and Larry[/quote
Or 18mm. rod for GPZ cranks. Mangus did a couple of cranks for me at his shop in Kenmore.A character for sure - the 2 stroke TF bike was a trip.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
